New user account in Tiger!? Help Digi!
posted this in the Pro Tools LE 6.9.2 Update for Mac OS X Tiger thread - no response, so I'm trying here:
Hello Digi, I just installed 10.4.2 & 6.9.2 and followed ALL the trouble shooting & set-up tips to the letter. The final tip of creating a new user account has me up and running ! In my usual user account PTLE quits unexpectedly on launch - just a bouncing dock icon for a few secs, then the 'app has quit' window. Any tips as to how I can make PT run on my main user account? It took me ages to set up how I want it and it's a pain to have to keep switching I'm using an Mbox 1 on a 1.5ghz Powerbook 512 ram. Thanks in advance....... |
Re: New user account in Tiger!? Help Digi!
The problem is that there is a corrupt preference file associated with your main account and you'd have to determine which one it is, which isn't going to be easy.
What I would probably do (and prepare yourself for some tedious times ahead..), is remove 1/2 of the preferences from your preferences folder, then restart and launch Pro Tools - if it launches, then you know that the corrupt preference is in the 1/2 that you removed. If it doesn't then you know it's in the 1/2 that are still there. Continue with dividing by half until you locate the culprit, trash it and you should be good to go. |
Hello Digi,
Thanks for your reply, I just tried emptying the entire contents of the preferences folder in my main user account to the trash, but the problem persists. Any other ideas? |
The only other possibility I can think of is that it's something in your user Library folder (MacHD>Users>your account>Library) that's the problem. How to deal with that, well, I can't say that I have a suggested method. I don't know what can or cannot be removed safely, so you may take a look and try to suss it out logically. I'd suspect the Caches and Application Support folders would be the first place to start.
PT set up new apple user account | epiphone | macOS | 2 | 03-01-2012 03:31 PM |
won't launch on one user account, will on another | Mark Dann | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 08-11-2005 10:11 AM |
Super User Account? | Animal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-17-2004 08:44 AM |
Digidesign User Account | steppenwolf68 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-17-2004 04:37 AM |
Still need to create a "new user account"? | Ealsh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-17-2004 07:24 PM |
