Old 10-03-2016, 08:57 PM
whole note whole note is offline
Default Pro Tools Perpetual Bundle (with 10/11/12)
Hello All,
I have a question about upgrading to 12.6 in Pro Tools.
I have copied and pasted a portion of my ILok terms to use as a reference; it should be attached to this message.
I 'believe' I am giving up my Upgrade and Support Plan and it will be replaced with a Perpetual Bundle (with 10/11/12).
Could anyone please elaborate on this information?
Thank you!
File Type: jpg Pro Tools Perpetual Bundle (with 10 11 12).jpg (26.1 KB, 0 views)
Windows 10
Processor: Intel(R) Core (TM) i7-4700M CPU @ 2.40 GHz 2.40 GHz
Installed Memory (RAM): 16.0 GB
System Type: 64-bit OS, x64-based processor
ProTools 2018.7.0
Audient id14
Old 10-03-2016, 11:05 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: Pro Tools Perpetual Bundle (with 10/11/12)
Originally Posted by whole note View Post
...I 'believe' I am giving up my Upgrade and Support Plan and it will be replaced with a Perpetual Bundle (with 10/11/12...
That is correct. You are upgrading from (surrendering) your existing bundle with 10+11+12 to a new bundle with those licenses plus the "Perpetual" license which authorizes 12.6. The new bundle is also perpetual (won't expire).
linkedin
Old 10-04-2016, 12:20 PM
Since I would be upgrading to 12.6, that means I could never go back to 10+11+12, as I could potentially - want to or need to go back - if 12.6 had some bugs and if I didn't renew my yearly subscription maintenance plan with Avid. My subscription ends very soon.
Windows 10
ProTools 2018.7.0
Audient id14
Old 10-04-2016, 12:36 PM
jeffro's Avatar
Guessing you might not have checked your iLok account yet - you'll see that a Pro Tools Perpetual Bundle (with 10/11/12) was deposited on 9/27. As the bundle's name suggests, that bundle contains licenses for Pro Tools 10+11+12 as well as a Pro Tools Perpetual license which authorizes 12.6. So you are covered for all the same 'legacy' versions that your existing bundle provides.
And to clarify... 'subscription' refers to licensing but you have a perpetual license, so whether you renew your Upgrade Plan or not either bundle will continue to work.
Since the new bundle simply adds 12.6 (and its licenses are still perpetual) you won't lose anything by completing the upgrade. Just need to activate the new bundle (and surrender the old one) in iLok License Manager.
linkedin
Old 10-04-2016, 02:36 PM
Okay, that's good to know that I still have Pro Tools 10+11+12!
I have to apologize for my word usage. At the time when I was preparing my message, I couldn't think of the term 'license', as my mind drew a blank, so I used 'subscription' instead.
Thank you so much for your detailed response! It is greatly appreciated. :)
Windows 10
ProTools 2018.7.0
Audient id14
Old 07-15-2017, 09:25 PM
younghustluh younghustluh is offline
I currently have pt 10. Thinking of buying the latest HD perpetual but I'm only interested at this time in running HD 10. After the term expires will I still be able to run Hd 10 or 11 or 12 ? I know at the moment u can only purchase 12. I just want to be sure I'll be able to continue using the HD ver of 10 after the support runs out.
Old 07-17-2017, 07:31 AM
jeffro's Avatar
A perpetual license doesn't expire, it will continue authorizing specific versions even if the Upgrade Plan has ended. Note though that a new Pro Tools HD software purchase does not include v10/11 licenses. If you need v10 you could purchase a used license and do a Transfer of Ownership. Check the Buy & Sell forum, etc.
linkedin
Pro Tools 12.2 not recognizing perpetual license gregmcohen Licensing & Accounts 3 07-19-2016 06:34 AM
Pro Tools 12 HD Perpetual License Renewal audioman1973 Pro Tools 12 0 02-24-2016 04:09 PM
Perpetual license - what exactly stays perpetual SixChurchStreet Licensing & Accounts 5 01-02-2016 10:43 AM
Pro Tools 12 Renewal of Perpetual License? jsbach Pro Tools 12 12 12-17-2015 05:30 PM
Pro Tools 11 perpetual license Picophone Buy & Sell 0 07-08-2015 12:44 PM
