Re: Pro Tools 11.3.1 / M-Audio Fast Track Pro
Doubling like you're doing it isn't true doubling. For that you need to sing the part twice. |
Are you crapping out? This was just getting interesting. |
SOLVED: I went back to Pro Tools 10.3.10 with the 6.0.7 driver for the M-Audio Fast Track Pro and it worked! It sounds exactly how it used to. Avid says the latest driver is compatible with Pro Tools 11, but it wasn't. It turns out the driver was in fact the issue. The latest driver was causing Pro Tools 10 to freeze and was giving me the static issue in Pro Tools 11. Could it have been that Pro Tools 11 uses aax plugins instead? I'm not sure if the plugin change caused audible differences. If I had my presets for the Pro Tools 10 plugins, maybe the same presets work differently in the aax versions of the same plugins? It seemed as if the Dynamic 3 compressor plugin in Pro Tools 11 was giving out much louder gain than the same plugin in Pro Tools 10.
I see the default latency is 512, but I was always used to seeing 256. Should I change it to 256 or leave it at 512? Last edited by skateboardharvey; 02-07-2017 at 10:17 PM. |
Skateboardkid has now deleted all his posts in both threads he started on this topic, and left this "Solved"-post. I'm unsubscribing and won't waste anymore time on this. |
#16
Yeah - it's become way past it's sell-by date
Pro tools 10 and M-audio Fast track pro | flako15 | Windows | 2 | 05-05-2014 08:28 PM |
Using M-Audio Fast Track 8R with Pro Tools 8 LE | drjordan | Tips & Tricks | 3 | 12-19-2012 12:20 AM |
Using M-Audio Fast Track Pro With Pro Tools HD???? | hemiloco915 | Pro Tools TDM Systems (Mac) | 11 | 04-30-2009 09:11 AM |
M-Audio Fast Track Pro and Pro Tools LE | Pete Seizure | General Discussion | 1 | 02-27-2009 04:53 PM |
Pro Tools & M-audio fast track | vreynoldsv | Pro Tools M-Powered (Win) | 3 | 12-19-2006 12:56 AM |
