Old 03-20-2015, 10:30 AM
jpk39 jpk39 is offline
Default Error "Could not create new document because Assertion in '/Volumes...'"[solved]
Hi there,
When starting PT 11.3.1, I am greeted with the following error message:
Could not create a new document because Assertion in "/Volumes/Development/151228/ProTools/DFW/MacBuild/../Views/UMenu.MacOS.mm", line 1549.
Attempts to create new session once program has booted are greeted with the same error.
Have gone through the usual PT troubleshooting (trashing preferences, etc.) but to no avail.
Can anyone help a guy out?
-jpk
Old 03-20-2015, 10:36 AM
Drew Mazurek's Avatar
Default Re: Bizarre error: "Could not create new document because Assertion in '/Volumes...'"
You trashed everything using this app?
http://duc.avid.com/showpost.php?p=2054400&postcount=1
www.drewmazurek.com
Old 03-20-2015, 10:39 AM
SOLUTION FOUND:
Holding down "N" key while booting. Forced Playback Engine dialogue. Changed playback engine. Error gone.
Old 02-23-2021, 10:29 AM
thesurfer26 thesurfer26 is offline
Default Re: Error "Could not create new document because Assertion in '/Volumes...'"[solved]
Thank you for the reply, it worked for me as well!!!
Old 03-10-2021, 02:42 AM
notedmusic notedmusic is offline
I get this occasionally but I just hit okay and try again and it works fine the second time.
Composer/Sound Designer
Pro Tools 11 HD, 64Gb ram, 12tb SSD, 1909
HD Omni/Thunderbolt Native
A bucketload of libraries
www.Reverbnation.com/jedediahjenk
www.soundcloud.com/jedediahjenk
notedmusic.wix.com/jedediahjenk
Can't create new document because of assertion error 1351... caleriggs macOS 33 12-26-2014 10:59 AM
Could not create new document because assertion angelstrack Pro Tools 11 5 11-03-2013 01:08 PM
Could not create new document because assertion spiker macOS 1 07-01-2013 02:06 AM
of a sudden error - could not create a new document because assertion in... petspets Pro Tools 10 0 04-08-2013 03:26 PM
PT Could not create a new document… assertion frcjt macOS 2 02-27-2012 05:29 PM
