Furman HDS-6 Setup
I just got my hands on a complete HDS-6 system for a steal (the pawn shop guy had no clue what he had... some of the mixers were brand new!)
Now I'm trying to set it up... before I just ran my DIGI001 (PT 6.4) into a cheap headphone amp and we split the same signal. I'd like to have 4 different sub mixes (drums, bass, vocals and guitars)... what's the best course of action for doing this? Thanks! |
Re: Furman HDS-6 Setup
Figured it out... I just created 4 Aux Tracks (guitars, vocals, drums and bass) and then I send the corresponding instruments to those Auxes.
I was then able to send the individual Auxes to 4 different outputs... each of which corresponded to an input on the HDS-6. This is perfect for tracking and when I'm ready to mix I can send the 4 Auxes to the Main outputs and I'm ready to go. |
Should be even easier than that. I've never used an 001, but if it works the same as all other Digi multi-out I/Os, the hardware outs show up on track sends. Say you're currently bussing all your guitars to buss 3-4, with an Aux track that has bus 3-4 In and Analog 3-4 Out. Just replace the bus 3-4 send on each guitar track with Analog 3-4 sends and ditch the Aux track.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
so instead of using aux busses from i/o I can just use my track sends? Then I can keep my main mix going to the main outputs?
Sure.
I tried it today and it works great! Its awesome!
Thanks! |
Furman HDR-6 setups | KroNEe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-25-2007 05:27 AM |
which furman should I get? | volume9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-14-2005 07:53 PM |
Furman ar-15 | Greene | Pro Tools TDM Systems (Mac) | 1 | 08-06-2005 01:18 PM |
Furman HDS question | doylemusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-05-2005 04:43 PM |
OT: Furman HDS-6 | Riad | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 08-30-2004 06:41 AM |
