Delete PT 8LE before installing PT 10 crossgrade?
I just purchased PT 11 Crossgrade from LE.
I want to install only PT 10 for now because my 2008 mac Pro won't run PT 11. I read that I should UNINSTALL my previous version of Pro tools (PT 8 LE) before installing the new version of pro tools. Is this true, do I have to uninstall PT 8 LE before installing PT 10, even though I have a crossgrade? |
Re: Delete PT 8LE before installing PT 10 crossgrade?
Thanks for the quick reply!
Where is this install manual? |
I have a Mac running OS 10.6.8, which version of PT 10 can I run. There are 3 in the download links, 10.3.8, 10.3.9 and 10.3.10.
Thanks, will do!
Which uninstall would you recommend, SAFE or CLEAN? |
OK. After Uninstall I still see the old DIGIDESIGN AND PRO TOOLS folders.
Should I just drag them to the trash? Are they of any further use? |
- iBook G3/800 14-Inch (32 VRAM - Tr) - eMac G4/1.42 (2005) - iMac G4/1.0 15-Inch "FP" (USB 2.0) - iMac "Core Duo" 1.83 17-Inch - PowerMac G4 867MHz + Dual 1.25 - PowerMac G5 Dual 2.0 + 2.3 - Mac Pro 1.1, 2.1 - MC374 - Mac Pro 5.1 - Digidesign Protool Mix Plus 5.1.3cs11, 6.4.1cs4, LE 7, LE 8 - Avid Pro Tools HD 9.0.6 + 10.3.10 Native + 11.3.2 + 12.5.2 , 003 , Avid Mbox 3 Pro , ProControl , Control24 ... |
Re-installing after crossgrade. | Stratomaster | Windows | 1 | 07-19-2011 08:08 PM |
help installing PT 9 crossgrade -ilokked out | End Over End | Pro Tools 9 | 8 | 06-06-2011 10:39 AM |
Installing PT9 Crossgrade on two computers? | tragibigzanda | Pro Tools 9 | 2 | 05-03-2011 07:10 AM |
Advice for installing PT 9 crossgrade? | RobRaden | Pro Tools 9 | 5 | 01-26-2011 03:58 PM |
Installing TDM - should I delete PTLE first? | Namaste | Pro Tools TDM Systems (Mac) | 4 | 12-06-2003 11:13 AM |
