Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 10-29-2019, 07:16 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Default ISRC question - previously released material
First time I have ever run into this. I have a client who wants to use songs he previously released on a greatest hits disc. He always has me add the ISRC codes and other meta data to the MP3 versions of his songs (along with other things like album name, etc).
It’s my understanding that an ISRC code represents a unique audio file, but not necessarily the album or track number. So when re-using an identical recording on a new album, it seems like I should make a version of this same audio file with the same ISRC, but simply change other meta data relating to album, track number, etc. is this the correct way to do this, or should we use new ISRC codes?
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 10-29-2019, 07:34 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
Default Re: ISRC question - previously released material
Yes as long as it isn't a different mix.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 10-30-2019, 02:06 AM
JFreak's Avatar
JFreak JFreak is online now
Different in any way. Even slight change on mastering forces a new ISRC as far as I know, for example changing output level to match other tracks.
Janne
Old 10-31-2019, 04:38 AM
Thumbs up Re: ISRC question - previously released material
Thanks guys.
- John
Old 10-31-2019, 09:14 AM
crizdee's Avatar
crizdee crizdee is offline
Ive always used the Same ISRC on remastered stuff. same song same artist same mix/version. Would have thought it would get confusing having the same song with different ISRC codes. Unless its a new project, different label bought the rights to release it or a compilation album for example.
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-31-2019, 10:48 AM
It is actually supposed to be tied to the mix no matter what label re-releases it or if it is remastered. That way royalties are kept straight.
Interview
Cannot play to previously recorded material without recording Nigel Moore Pro Tools 12 4 05-04-2016 06:24 AM
Previously recoded on Mac, now have a pc ChrisBattista 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 10-31-2006 11:07 AM
ISRC CODES volume9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-19-2005 01:10 PM
ISRC codes poppy Pro Tools TDM Systems (Mac) 1 04-06-2004 11:07 AM
ISRC Code advid Digidesign Hardware & Software 4 10-25-2002 09:34 AM
