Old 02-12-2015, 02:39 PM
blizzard blizzard is offline
Default Can't Drag and Drop from Workspace
Hey All,
Using PT11.3.0 and I can't drag and drop from the workspace at all. Importing audio works fine. Is this a permissions thing? Can't seem to figure it out.
Any ideas?
Blizzard
DAW - Asus P9X79 / 32GB / i7-4820K / WIN7 PRO / VEPRO 5
PT 11.3.0 / Blacklion 003R / Microclock
Macbook Pro Retina / 2.8GHZ / 512GB SSD / PT 12.4
Old 02-12-2015, 02:52 PM
Brandonx1 Brandonx1 is offline
Default Re: Can't Drag and Drop from Workspace
Are you on windows 8?
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 02-12-2015, 04:35 PM
Nope, Windows 7
Old 02-12-2015, 07:12 PM
guitardom guitardom is online now
There is some UAC issues I believe going on in the recent PT builds. See if alt+tab works with PT open to switch program views. It also seems to be affecting some plugin modifiers as well.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 6800k
Win 10
Old 02-12-2015, 07:34 PM
My alt+tab works fine (use it like crazy) and I have UAC set to "never notify" as recommended by AVid.
Old 02-13-2015, 12:40 PM
The Weed's Avatar
The Weed The Weed is online now
In Windows 8.1 and PT 11, if I have PT set to "Run as Administrator", I can't Drag and Drop to a Track. Turn RAS off, and I can Drag and Drop. Could it be the same for Windows 7?
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 02-13-2015, 03:54 PM
Cheers,
This is odd....and backwards. I will check it out.
what I did figure out today is that if I modify this registry key which futher shuts UAC down as its not completely off when you shut it "off" in the control panel, it will allow drag and drop to work. I am working in 8.1
So, just open regedit and locate this key.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Policies\System
In the right pane look for EnableLUA and modify its value to 0. Close regedit.
pro-tools-pc.com
Intel I7 6800k
Win 10
Old 02-13-2015, 07:25 PM
The Weed's Avatar
Steve, see this thread.
Thanks,
Old 02-13-2015, 08:39 PM
Thanks,
Interesting. I never had an issue with it until now and it seems to be that way for quite a few people. Wish there was more consistency with this! That reg hack worked for me, but it does stop windows store apps from working. I will have to re enable it and try turning it back on.
pro-tools-pc.com
Intel I7 6800k
Win 10
Drag and Drop from Workspace VERY Slow gfcurtis macOS 36 01-29-2015 09:08 AM
WorkSpace Drag and Drop Not Working in PT11? quantise Pro Tools 11 0 08-14-2013 07:29 AM
Workspace drag and drop issue ZeSnail Post - Surround - Video 3 12-25-2011 08:11 AM
Workspace browser drag and drop problem Greene Pro Tools TDM Systems (Mac) 0 02-28-2007 07:46 AM
Stereo File Drag 'n Drop from workspace bug? Rich Breen Pro Tools TDM Systems (Mac) 0 11-09-2004 01:01 PM
