Old 08-30-2010, 12:10 PM
Table Syrup Records's Avatar
Table Syrup Records Table Syrup Records is offline
Default Input / Output channel selection Q
This Q is in relation to my 6.4.1cs4 Mix rig
If I hold Alt in Windows, or Option or whatever on Mac, I can select an input/output and ALL other tracks will go to the same input.
Is there a way to do this where all subsequent tracks will follow to the next input/output????
Example:
Ok, so say I start a new session,
New Track - Say... 32 Mono Audio Tracks -
They will come up in order of A 1-8, B 1-8 and so on
Is there a modifier function where I can make inputs/outputs select in order like when creating multiple new tracks????
Scenario - I get to a live gig, I want my inputs ordered from 1-32 via A 1-8, B1-8 etc like above, this works by simply creating the tracks... gravy...
BUT... I also want my outputs routed the same way....
Is there a way to hold a modifier or something, select the Output channel for track one and select A1, and all the other 31 will go to A2, A3 etc?
The reason I want to do the output thing is so the 888 meters will reflect my levels for additional reference... and then I can also turn off my monitor and just watch the 888s
Anyone????
Right now, without a hotkey/modifier function, I would have to do each one individually, which drastically increases my setup time... and it's a pain.
(I don't like using template sessions, so I'm looking for another solution here)
Maybe something simple?
Shorty: Table Syrup Records
Mac Pro 5,1 3.33 GHz Hex, 32GB
EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23"
OSX Sierra
Pro Tools HD 11.2.2
Waves IOS, IOX, STG2412
Extreme Server (x2)
Logic Pro X, DSP Quattro, Final Cut Pro X
Waves Mercury+SSL+AbbeyRoads
Trident S65 with embedded US-2400
Live:
2012 Mac Mini, Dual SSD, i7 2.4, 16GB
Win 10, OSX Sierra
LV1, MRSG
Hardware from above (same gear)
Dual Dell P2418HT Touch Screens
Waves Icon X (x2), M, with Screens
Custom enclosure
Old 08-30-2010, 12:22 PM
Drew Mazurek's Avatar
Default Re: Input / Output channel selection Q
Option Command will sequentially number all.
Shift Option Command will sequentially number selected.
www.drewmazurek.com
Old 08-30-2010, 12:27 PM
Thanx D... is something missing there? Or do both key combos do the same thing :) ??
Option Command input? Shift Option Command output? Or both same function.... ???
eh, I'll figure it out... thanx!!!! :)
OSX Sierra
Pro Tools HD 11.2.2
Extreme Server (x2)
Live:
Win 10, OSX Sierra
LV1, MRSG
Custom enclosure
Old 08-30-2010, 12:43 PM
Stig Eliassen's Avatar
Shift-Option is Do to selected in PT.
Old 08-30-2010, 12:45 PM
fixed!!!
Do not post while working!!! and use copy/paste!!!
www.drewmazurek.com
Old 08-31-2010, 07:48 AM
Cool cool, did it last night...
In the past I only monitored in PT, I think it'll be nice to have them on the meters :)
Would have been way cooler to simply toggle back and forth between input/output on the 888 meters, but oh well. Seems like I'll be working the mixer harder now
Ok, last scenario
This particular rig is 32 Channels,
Say I'm pulling up to 30, I could insert to Out 31+32 so I can output the mix, post fade from pro tools, which would be good for podcasting, or for 'board mix', etc....
I tried to copy over an insert to another track and I could not....
Is this not possible?
And if it is, is there a way to drag it once and have it copy/duplicate to all tracks?
I tried a slew of combinations of modifiers and could not get it....
Sorry for the possibly silly Q's... I'm actually very fluent in PT, just not as much on the Mac, at least with the key commands...
Otherwise I can just create one new track, set it up with the insert/send, and then duplicate, and then set sequential inputs/outputs...
OSX Sierra
Pro Tools HD 11.2.2
Extreme Server (x2)
Live:
Win 10, OSX Sierra
LV1, MRSG
Custom enclosure
Channel I/O keeps loading old I/O and not "no input"/"no output" Arve Gotfredsen macOS 4 02-12-2013 04:38 AM
32 Channel Input / 16 Channel Output Device(s)? tcstx Pro Tools 9 33 02-07-2011 03:04 PM
2 MIDI Input Tracks Output to Same MIDI Channel altemir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-05-2005 03:20 PM
noinput is the only selection in the channel input Marty_DD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-12-2005 05:45 PM
noinput is the only selection in the channel input Marty_DD Pro Tools TDM Systems (Mac) 2 11-09-2005 05:08 PM
