  #31
Old 01-20-2019, 06:49 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: HDX Doesn't Like To Run At Low Buffer Setting
Guys, I think this is a general issue with PT, it doesn't matter whether native or HDX.
I just swapped the CPU of my iTrashcan from 3.7GHz 4-core to newer version 3.0GHz 10-core, which is slightly more powerful than original 12-core as per GeekBench4 -- all of a sudden I can run PT with 32 buffer very smoothly and without any hiccups whatsoever. After brief testing I was actually thinking okay now is the time to try 32 buffer, but when I went to playback settings I noticed I was already running low buffer. Didn't even have to turn hyperthreading off.
So it seems PT likes many cores..?
Janne
  #32
Old 01-20-2019, 07:40 AM
Southsidemusic's Avatar
We got one 6 core and one 12 core both which runs great at 32 buffer size. Tested with HDX setup on the 6 core and no issues. We run several of the new Apollo X8P and X16 now so the HDX is not getting used much.
The Native processing power and the 32 buffer is far better and more stable than the HDX ever was for us so I can understand that your 10 core does a better job with HD Native than the 4 core. No real surprise there
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
  #33
Old 01-21-2019, 08:14 PM
JFreak's Avatar
My surprise was 10-core works so well with hyperthreading on, whereas the 4-core hyperthreading needs to be disabled before 32 buffer is usable
Janne
PT 9 Hardware setting - 003 doesn't show up maestrotim macOS 2 06-03-2011 08:49 PM
setting marker doesn't work AchimHamburg Pro Tools TDM Systems (Mac) 5 01-27-2010 07:29 AM
No 2048 Buffer Setting? Angus202 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-17-2007 02:39 PM
No H/W buffer setting of 128/Please Help... SoftDesign 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-19-2004 06:38 PM
What is everyone's HW Buffer setting on avg? davetron5000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-20-2004 08:36 AM
