What bitrate do i set my Digi002R to?
I have it set at 44.1. should i use 48? what are the benifits of either?
i have a P4 2.3 gig with XP home edition. thanks |
Re: What bitrate do i set my Digi002R to?
Either sample rate will work fine. The thing you want most is to record at 24 bit which gives much better headroom so you don't have to run your input levels quite as hot. When you BOUNCE TO DISK, you can use a dither plugin to convert to 16 bit, or bounce at 24 bit and import the bounced audio to a new session for mastering. This is where I trim the ends of the file and add a fadeout if needed, and put the dither plug(always in the last insert point). 48K has slightly better high frequency extension but requires sample rate conversion if you are going to CD(which is 44.1K and 16 bit only). Do a search for "dither" as it has been explained very well other places on the DUC.
thanks, i appreciate the quick reply.
From what I've read, most professionals record audio for CD at 44.1K, and audio for video at 48K. Always 24-bit.
Mike
-- Mike - HP Spectre x360 Convertible 14t-ea100 - 2.9 GHz (5.0 Max Turbo) i7-1195G7 32GB RAM, OLED 3k x 2k, Iris Xe Onboard Graphics - Windows 11 - PT 2021.12 - PreSonus Quantum 2 - PreSonus Studio 24c - Mackie Onyx 1640i - Samsung T3 and T5 SSDs - Various USB2/3 and Firewire HDDs |
What bitrate when using Transfuser | Southsidemusic | Pro Tools HDX & HD Native Systems (Mac) | 6 | 02-02-2012 06:07 AM |
Help...bitrate issue | keithaska | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-10-2009 09:27 PM |
Bitrate question | syed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-04-2007 02:21 AM |
MP3 bitrate and Tag Type | jlnelson19 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-12-2004 05:46 PM |
AES output bitrate on 888/24 | wiz | Pro Tools TDM Systems (Mac) | 9 | 07-11-2000 11:18 AM |
