Preamp Gain Problem
Hello,
The chain is 2 KM184's drum overheads to Great River MP2 to 888/24 to PT Mix. For some reason, even with the gain on the preamps only up to about 12, the A/D is clipping. The drummer isn't playing loudly and the mics are 5 feet above the kit. I don't understand why it's clipping the converters. Is the output of the KM184's extremely hot or something? Please help. Thanks in advance! |
Re: Preamp Gain Problem
Hello Pet:
This may be a combination of things. First, unlike the original KM84, the KM184 has no -10 db pad. Although you say your drummer is not playing loudly and the position of the mikes is five feet, there is a possibility you may be overdriving the 184's. Secondly, although I do not own a Great River MP-2 (and it looks mighty impressive), I would say the combination of the position of the impedance switch (which selects between 300 and 1200 ohms) coupled with the position of the Output Level control may have a lot to do with your problem. Since the KM184's are fairly "hot" compared to the old KM84's, you will probably find yourself needing to attenuate your gain stages significantly. Best Regards |
Maybe your 888 is internally set for -10 dbV line level operation ?
If that is the case you may have a problem matching this with a preamp output probably calibrated for +4dbu. If you have a output gain on your preamp, then its fine. If not, you will have to cheat and lower the Mic input gain, but at the expense of quality. Or in the end you may have to change the 888 operating level. |
For now the solution I'm using is to patch my cleanest compressor (RNC) and use it's output level to attenuate the signal going to the A/D. While this isn't an ideal solution, it works until I find out what's happening. If anybody has some idea as to why the output of the preamp is clipping the A/D even with the preamp gain turned all the way down please tell me! |
[quote]Originally posted by PetRawks:
I'll get a chance today to run the 184's through different two channel pre's and I'll smack some drums out in the live room. This way I can determine whether the GR is the culprit or further process of elimination is required. Thanks guys! I'll keep trying. |
You're probably thinking of what happens when sending an unbalanced signal into a balanced input, in which case you'll usually lose 6dB. Also, impedance can affect level. It's just not usually a big problem with modern gear until you start multing sources. |
Hello again:
I was looking at the Great River MP-2NV, which apparently is not the same as your MP-2. MY FAULT! You probably need to start at the head of the signal path and work through it. Try another set of mics with the Great River to see if the distortion disappears. If the distortion remains, try a different preamp and so on... The main thing is to isolate the offender in your current chain by substitution. Once you do, you can take steps to correct problem. Best Regards |
Hello again:
I was looking at the Great River MP-2NV, which apparently is not the same as your MP-2. MY FAULT! You probably need to start at the head of the signal path and work through it. Try another set of mics with the Great River to see if the distortion disappears. If the distortion remains, try a different preamp and so on... The main thing is to isolate the offender in your current chain, by substitution. Ultimately, you should be able to isolate the offender. Once you do, you can take steps to correct problem. Best Regards |
My first guess would've been that the 888 is internally set to -10, but since that's not the case, have you checked the calibration (input trim pots) of your 888?
Larry Cellar Dweller Productions PT 2020.3.0 HDX, HD IO 16x16 analog, 192 I/O, Control|24 Mac Pro 2019 16-core, 96GB RAM, OS 10.15.2 |
test this :
try inputing a -10 dBV analog line source (consumer cd player, tuner, DAT etc) directly into your 888. I assume you have a proper cable for going from a unbalanced to a balanced connection - If the level in PT seems decent, then your 888 has inputs set for -10 dbV - If on the contrary the input level is very very low and there is nothing you can do with the trim pots, then your 888 is set for +4dBu. BTW the operating level of the 888 can be set differently for ins and outs I think (haven't checked on the manual though...) hope it helps |
OMNI Preamp gain | stargazer | Pro Tools HDX & HD Native Systems (Mac) | 4 | 05-17-2012 12:43 PM |
OMNI Preamp gain | stargazer | Pro Tools TDM Systems (Mac) | 3 | 05-14-2012 02:59 PM |
Gain, level on preamp vs gain on Digi (guidelines)? | rcook349 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-04-2007 08:18 PM |
Weird M-Box Preamp Gain | .:*Robot Boy*:. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-08-2005 04:42 AM |
digi001 preamp gain | Digi-Slime-NYC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-12-2001 07:53 AM |
