Old 07-24-2018, 07:24 PM
Hemislip Hemislip is offline
Default Re-automate DB 33 Leslie speed Control ?
I like my organ parts, but how do I change or re-automate the leslie speed?? Thanks in advance!
T
Old 07-24-2018, 08:13 PM
Sardi Sardi is online now
Default Re: Re-record DB 33 Leslie speed Control ?
From memory, there’s only slow and fast speed settings.
If you’re hoping to sync the effect to tempo, you won’t be able to.
Old 07-24-2018, 08:28 PM
Thanks for replying! I want to have some parts to be automated to les slow speed. The whole thing was recorded on les fast speed. It doesn't have to be tempo synched.
T
Old 07-25-2018, 04:40 AM
T
Do you have a modulation wheel/stick you can use? A lot of Leslie simulations use that for slow/fast speed control. An option is to manually input numbers/data in the event list for the mod wheel. Or draw in a curve in the automation lane for the mod wheel.
Old 07-25-2018, 06:05 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Two ways. MIDI and or track automation.
Track is my prefered and the most flexible way.
Track auto(plugin tab enabled).
Right click any knob on plug to automate. Enable
Track to write auto
Play and engage with the plugin as desired
Edit if needed.
Note speedup and speeddown can be altered on page 2 of the plug.
Old 07-25-2018, 09:59 AM
Default Re: Re-automate DB 33 Leslie speed Control ?
You also could add a lane(assuming an Instrument tracks) and set its view to the CC for speed and you will have a lane of automation you can adjust with your mouse(add break points, move breakpoints, etc). It just takes a minute to figure out and display the correct info(but I have done this many times in the past)
Old 07-25-2018, 08:12 PM
Thank you so much everybody!!! I am going to try these things and then I will tell you the updates... Thank you again.... Tony P
Old 10-16-2018, 03:28 PM
Everybody!
The Leslie Automation worked!! (applying "speed" to the plug-in automation) ... worked like a charm as I can toggle the leslie switch on the plug in.
Thanks again !
Tony P
Old 12-26-2018, 01:32 PM
LarsC LarsC is offline
Thanx a lot. Spend a lot of time trying to solve this.
Simply add "Spd" - automation works
D-33 Leslie speed control Stickman7 MIDI 7 02-27-2013 09:13 AM
DB-33 Leslie Control JBRecording Virtual Instruments 2 04-25-2010 01:18 AM
How to record at different speed mothygoggles 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-08-2005 10:13 PM
Record at slow speed??? macaholic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-02-2002 10:54 AM
is there a way to record in 2x speed surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-27-2001 02:23 PM
