Old 10-23-2012, 12:32 PM
12stepcornelius 12stepcornelius is offline
Thumbs down Annoying Playback Issues
I just upgraded to PT 10 from LE. I've been trying to begin recording but my PT is virtually unusable due to playback issues. One of them is that when I am recording an instrument through DI, it is incredibly fuzzy and I sometimes I also hear echoey pops that resonate when I strike a note. If I mute the track it sounds fine, though when playing back after recording I get no audio, just the echoey pops. Another major problem is the error message that says, "CPU usage is holding off USB audio. Remove some plug-ins, delete some tracks, or increase the "H/W Buffer Size" in the Playback Engine dialog. (-6104)." This is the kicker that makes my PT unusable. I try increasing the buffer size but nothing. The Playback Settings I've been trying are
H/W buffer size: 64 samples
Host Processors: 4
CPU Usage Limit: 99%
Ignore Errors During Playback/Record (checked)
Plug-In Streaming Buffer: Level 2
And I'm selecting 48 KHz initially when starting a project.
Any ideas of why this is screwing up? Thanks
Old 10-24-2012, 06:50 AM
loosestones loosestones is offline
Default Re: Annoying Playback Issues
turn off wifi, and Firewire DHCP routing. should take care of most -6k errors.
Old 10-24-2012, 07:47 AM
dissensus's Avatar
dissensus dissensus is offline
i got rid of the "CPU usage is holding off USB audio" message by inserting a powered usb2 hub (belkin) between my audio interface and my usb3 equipped mac.
hope this helps.
Old 10-24-2012, 08:52 AM
Ok well my FireWire was already off I believe. I'll try turning off my wifi next.
Old 10-24-2012, 01:53 PM
Ok, so another weird thing. Just booted my pro tools project back up after turning off wifi and FireWire. No more error message as of yet, but now whenever I record something, it only plays back through my laptop speakers, not through my mbox2. What's going on now? Frustrating.
Hint!: Set a long post-roll time to avoid annoying playback stops! EricWillhelm Tips & Tricks 4 07-01-2013 05:11 PM
Annoying midi playback error Herokazz Windows 1 04-04-2012 03:59 PM
Annoying playback behaviour m4tune Pro Tools TDM Systems (Mac) 2 06-30-2011 05:29 AM
INTEL MAC PRO 7.3.1cs1 Annoying issues MESH@ZU Pro Tools TDM Systems (Mac) 2 05-30-2007 02:38 AM
MIXDOWN EQ ISSUES - ANNOYING / NEED HELP AHorrorstory.com 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-09-2004 11:28 AM
