Old 01-08-2003, 01:00 AM
Delusion Delusion is offline
Default nasty metallic sound on mixdown problem
has anybody ever had a nasty "metallic ring modulation" type sounds in their mixes?
i get this when i bounce down internally in pro tools 5.3 with my 002. the sound is not there when i'm monitoring the tracks before the bounce, but when it appears everytime i do a mix via bounce.
any help is appreciated!
Old 01-08-2003, 03:06 AM
vocalvoodoo's Avatar
vocalvoodoo vocalvoodoo is offline
Default Re: nasty metallic sound on mixdown problem
I have had a similar problem when bouncing dry voice to mp3's. I fixed it by selecting "Variable bit rate" instead of "Constant bit rate" in the bounce options.
Don't know if we are talking about the same thing but my MP3's were sounding very worbley/metallic on the high end. Almost like that crappy sound that Real Audio files have. Doing the above fix corrected it.
Hope that helps.
Old 01-08-2003, 11:21 AM
thanks for the idea vocalvoodoo. your description sounds like the problem i'm talking about. i'll try it when i get home tonight and let you know how if it works.
thanks.
Vocal plugin (electric, metallic sound) for broadcast production? How to do it? verd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-22-2009 11:53 AM
PTs HD 7.4cs4 causes nasty crunch sound boneboy Pro Tools TDM Systems (Mac) 0 04-28-2008 03:39 PM
Mixdown - mixdown pitch shift problem kakeneeditoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-03-2007 03:38 PM
Pitch shift metallic sound problem K.B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-26-2003 03:55 PM
Crazy metallic sound in heaphones..please help! elwoodblues 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-10-2003 12:09 AM
