Old 11-15-2010, 12:55 AM
chrissyb chrissyb is offline
Default Can't use sessions at 44.1kHz
I've searched around for this - because I have read it somewhere, but i can't find it again...
Basically I can't run Pro Tools at 44.1 because of loud pops and clicks - although it runs fine at 48. i went to open a template which are saved at 44.1 at had the problem - immediately closing that and switching to 48 solves the problem.
I'm using an eleven rack...So basically I can't use a session saved at 44.1.
Any ideas - thanks in advance....
PT LE 8.0.5
Mac OS 10.6.8
Imac i5
Eleven Rack
Axiom Pro 61
Old 11-15-2010, 02:21 AM
crashhak crashhak is offline
Default Re: Can't use sessions at 44.1kHz
Make sure sample rate of session and eleven rack sample rate match. If it doesn't resolve problem. Let's hope not, but your unit might be defective. I suggest call avid for repair. If you bought defective unit, you're covered by 1 year warranty.
Old 11-15-2010, 08:22 AM
Thanks for the reply.
I'm surprised it's that final...I can't remember actually if it ever worked at 44.1. I think I created my sessions at 48.
If PT is closed and I try and change the sample rate - I have the problem, and I guess you're pretty limited to what you can try beyond this. My firmware is up to date - I haven't upgraded to the PT 8.0.4 though.
Is there really no over option other than it's faulty - that's the Mbox and this in a row I've had problems with....
Chris
PT LE 8.0.5
Mac OS 10.6.8
Imac i5
Eleven Rack
Axiom Pro 61
Optimization trick : mix with 44.1kHz sessions? Fastudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-26-2007 11:39 AM
Converting 44.1khz .wav's to 22.1khz MP3's bruceup Pro Tools TDM Systems (Mac) 1 09-04-2003 07:02 AM
24 bit at 44.1kHz C.D.'s GORILLA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-25-2002 11:20 PM
48khz or 44.1khz sessions? yuppie Tips & Tricks 12 11-12-2001 12:28 AM
44.1Khz or 48 krhaarmeyer Tips & Tricks 71 02-15-2001 05:56 PM
