Help! Error 9128 "Your\'e running out of CPU power. Take out some plugins to free..."
I keep running into this error. I did not run into it before I went to Win xp (except when I was REALLY taxing the system) But now, with just one or two plugins, it is giving me this error a lot. I am running a quicktime file in the session (and yes, I have turned the QT track to "Blocks) But it happens even when I am not playing the QT file. I have tried turning everything that is running in the background off--to no avail. My buffer is set to 1024. any suggestions?
I have a P3 800Mhz, 256 RAM, win xp--with audio and video coming off a seperate drive from the system drive thanks! |
Re: Help! Error 9128 "Your\'e running out of CPU power. Take out some plugins to free..."
I know it's obvious but you need a faster system.
yeah, I know, but why was I not getting these errors before when I was on win 98. I'm thinking maybe I don't have all my settings right (in iether xp or in PT when I re-installed it)--any suggestions?
Yeah, I'm getting that error alot too since moving from Win98 to XP Pro. It sucks because I got way more plugins in Win98. I'm using a Pentium 3 1ghz in my machine. One thing I did was switch the buffer size hit play wait and the error pops up, then switch it again and hit play and it usually works. Pretty sad though, because I have almost no RTAS plugs running in my session I copied virtually everything over to Audiosuite and the error almost never fails to appear. [img]images/icons/mad.gif[/img]
You may also try a Hardware profile running only the bare necessities required for your desired audio applications (Protools, etc)...
Also, I would possibly run a defrag on the system drive and try to do that on a regular basis (XP requires more HD space to run efficiently). Hope this helps [img]images/icons/smile.gif[/img] |
Sounds like a common problem. Think I might wait until PT 6 is available, and then get a G4 dual proc. Thanks!
Hi LATablette-
Guess you can geta a Mac if you'd like. [img]images/icons/smile.gif[/img] My old P3 800 system did better or equal on the DaveC than the G4's posted. Still, as stable as that setup was for me, it was power limited. There's a world of difference between it and the XP 1700 im playing with now. You're asking alot of a P3 800 running PT with Quicktime files, which is something you weren't doing in 98. Just some random thoughts. Good luck- |
I read that you have only 256 of ram.Digidesign specifically recommends 500meg for the 001.
It would surely be the most cost effective way to up your CPU power. |
Unfortunately, that hasn't been the case on the DUC.
With 256 or better ram, it's more CPU power that makes a difference as far as plug in's go. Quote:
After asking digi support the same questions they answered that winXP and protools 5.3 (32Trk) consume more power than a 5.1 98/me system, therefore suggesting to upgrade to a faster cpu. I upgraded to a amd 2400 with 1gig of ram and my machine is realy clean, but the error occurs, especially at 128 buffer size. If U guys finbd a solution that'll be great.
Alberto Lombardi Carbon - Pro Tools Mac Mini M1 Ferrofish 16 I/O www.albertolombardi.com facebook - instagram - youtube |
PLEASE HELP! PT 8 -- "running out of CPU power" at <15% of CPU usage | jsbeeth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-01-2011 08:04 AM |
"You are running out of CPU power" POPS, CLIKCS and HELL IN PT | DCstudio10 | Pro Tools M-Powered (Win) | 24 | 07-12-2010 03:50 PM |
what actually causes the "running out of cpu power" error... | CamM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-30-2009 04:49 PM |
error 9128 running out of CPU power with XP | in10shun | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 07-12-2002 02:49 PM |
running out of cpu power, error 9128?? | Florian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-07-2002 11:15 AM |
