clock problem!! 3X192 - 888 - 882
Hi, can anybody help with this?
I have 3 192's one 888/24 and a 882 This is how they're connected and set up 192A ----> expansion to 192B 192C ----> Legacy to Y cable to 882 and 888 How should I hook up clock for the 2 legacy things? (192's are ok in loop) I tried clock routing like this: 192C ------> 888 ------->882 (882 DOESN'T WORK) 192C ------> 882 (FINE) 192C ------> 888 (FINE) if I pick clock from a differnet 192 then the one I attach the legacy peripheral to, it doesn't work. (888 clock from 192C - 882 from say 192 A) PS: System used to work hooked up like this (2X192's - 2X888 - 882) 192A ----->legacy Y to 888a - 882 192B ----->legacy to 888b 192A ----->clock 882 to 888a to 888b never used a termination Than you in advance, it's really driving me nuts
Alberto Lombardi Carbon - Pro Tools Mac Mini M1 Ferrofish 16 I/O www.albertolombardi.com facebook - instagram - youtube |
Re: clock problem!! 3X192 - 888 - 882
You could first try 192C --> 882 --> 888 and see if it mysteriously works, doesn't cost anything. Sometimes I've seen that the clock output of a black interface doesn't work for some reason, you may have one of those boxes. But if not, go to your local electronics store and buy a passive bnc splitter so that your 192C kind of has two ext.clock outputs. It drops the signal level somewhat but unless you have long cables it doesn't matter.
What you suggested used to work, but now all 192's and 888 are in adifferent room from 882 and I would have to buy a long bnc and pass it through the wall. I will try both solutions! PS: why didn't using another 192 (A or B) to clock the second legacy interface work?
On the other hand; if you had three card config, you could connect all three HD interfaces straight to cards and use the legacy expansion from two of them. So perhaps this is a good time to buy another dirt cheap pre-owned Accel card :)
I wish I could..
my sys is kinda blocked/maxed out. I would really need the extra card to connect another 8ch of out to consolle, but my PC has only 2 PCIx slots.. and my old G5 is slow as hell Thanks for the clock info, didn't think about that!
Don't know what PT version you want to run, but any G5 runs PT HD 7.2 ... 7.4 just perfectly on Tiger. Just do a fresh install and refuse your urge to install anything extra to that system :)
Problem detected with audio clock. Check your clock source and sample rate. | sleeptalken | Windows | 7 | 08-10-2021 01:17 PM |
Problem detected with audio clock. Check your clock source and sample rate. | teleguy2 | Windows | 6 | 06-26-2015 01:47 PM |
Problem detected with audio clock. Check that your clock source and sample rate are c | Solow1nonly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-06-2011 08:22 PM |
problem detected with audio clock. check that your clock source and sample rate are c | angeleda | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-05-2010 07:09 PM |
"Problem detected with audio clock. Check that your clock source and sample......... | ASD15 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 03-26-2010 03:40 PM |
