Available Memory?
Just want to verify my understanding about the available memory for a PT9 session. Since PT9 is still a 32-bit application, it still runs in a 4GB address space, even on Win 7 and OS X 10.6. Is that correct?
Re: Available Memory?
That is my understanding.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
But won't have to share any of that with the OS
For OS X that was true prior to 10.6. Are you saying that Win 7 doesn't reserve 2GB per instance for its use like XP did?
If you use 64-bit Win 7, then the total amount of memory available for all programs is huge. If you run a 64-bit application it can use a huge chunk of memory as well. If you run a 32-bit application it can only access a maximum of 4Gb of memory. If you run that in a 32-bit operating system, it has to share that memory with all the other programs running on that system, including the operating system itself. Effectively this means that you will be limited to about 3Gb if you are just running Protools. Not a problem in itself unless you use virtual instruments, e.g. some drum kits in Superior can load over 1.5Gb of samples with some presets... So running a 32-bit app in a 64-bit OS means it theoretically has access to 4gb of memory in it's own application space. Though this probably depends on how the app itself has been coded. The other advantage of using a 64-bit app is that some VIs can be run externally to Protools with their outputs rewired into protools. |
Kontakt Memory Server (KMS) Could not start MemoryServer. Memory Extension will be... | John_Toolbox | Virtual Instruments | 5 | 12-29-2011 10:03 AM |
MEMORY ERROR MESSAGES- Strange memory loss | hwill2008 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-23-2010 08:14 AM |
Memory is Low? Quit and Allocate more memory to PT | Unite | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-08-2004 05:38 PM |
Will PC2700 memory work in PC2100 memory slot? | dfusion | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-08-2004 09:30 AM |
Promting lack of memory on PC with adequate memory! Any tips? | will22 | Digidesign Hardware & Software | 12 | 09-20-2001 08:36 AM |
