Old 07-20-2011, 07:00 AM
enzomolinari enzomolinari is offline
Default Do I need Complete Production Toolkit for PT9?
Here is my problem:
When I select one or more Midi Tracks and one or more Audio Tracks at the same time and hold shift + option an then press the record enable button on on of the Tracks only all the Audio tracks or all the Midi Tracks are record enabled. So it works with multiple Audio Tracks only or multiple Midi Tracks only but not when I try to arm MIDI and Audio Tracks simultaneously. Why not?
I know that you can select record-enable as a mix attribute within a mix group when using Pro Tools HD9. I have PT9, not HD. So could someone try if it is possible to arm MIDI and Audio Tracks together, when using a mix group with the mix attribute "record enable" instead of selecting them all and holding shift + option while clicking the record enable button.
Thanks
[IMG] code is Off
PT 10 Audio track will not record enable brethart Pro Tools 10 3 06-25-2013 05:58 AM
BUG? selecting midi track arms record for selected track browniespeaks Windows 40 06-10-2013 11:41 AM
Track one record enable button quit working? bookerfatz2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-12-2010 11:20 AM
No Audio track monitoring with record enable in pl andre67 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-05-2006 12:28 PM
No Audio track monitoring with record enable in pl andre67 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-05-2006 11:21 AM
