Old 03-11-2008, 12:57 AM
sleadley sleadley is offline
Default Older Expansion Chassis Compatibility question.
I have an older 7 slot Digidesign Branded SBS Chassis and want to know if it can be used with an HD core and Process card and a G5. It is obviously an PCI chassis with a Model # MH477 and a Part # 85466201. I am not sure if this is 32 or 64 bit. But before I connect it I want to know if it is compatible with this setup. I intend to run 7.4 and 10.4.9 OS.
The info I have managed to dredge up makes this far from clear to me. Any help would be appreciated.
Thanks in advance.
Simon L.
Plan for the worst, Hope for the Best.
www.trackdown.com.au
Old 03-11-2008, 11:24 AM
Avid's Avatar
Avid Avid is offline
Administrator
Default Re: Older Expansion Chassis Compatibility question.
That would be a 32-bit chassis:
http://www.digidesign.com/index.cfm?...4&itemid=23351
The Digidesign & SBS (Bit3) 7 Slot 32-Bit Expansion Chassis are officially qualified for use with Pro Tools|HD and Pro Tools|HD Accel PCI card systems with Pro Tools HD 7.0, 7.1, and 7.2 for Mac OS X.
Not tested or qualified with Pro Tools 7.3 and higher, so I can't tell you whether it would work with 7.4. Not something that we have tested.
Administrator
Old 03-11-2008, 01:45 PM
Thank you for the reply. As long as I know it will function without damaging the cards I will give it a try and see what happens. This will allow us to use an HD3 with a SCSI card otherwise we cannot use our SCSI drives on this system in the mix room.
best regards
Simon L.
Old 08-01-2008, 04:14 PM
forjam forjam is offline
Default Performance issues with 32 bit chassis
What is the performance difference between a 32 7 slot chassis and a 64 bit chassis running HD3 Accel on a dual 2.7 G5 PT 7.4?
8 Core Harpertown 3.0
Apogee Symphony 64 / Rossetta 800
Old 08-01-2008, 04:24 PM
thomasHake thomasHake is offline
Default
Hi All
Do you know this box ?
http://virtuavia.eu/shop/pci-express...nsion-box.html
I got a home studio at my home and I bought a Protools HD Core card was so cheap . I got a PPC G5 at home but not PCI ! its pCIe (the slots)
I have searched the pci-express-to-pci-expansion-box I fond Magma but I would like to buy cheaper. Anyway what do you think about to this box and I don't know it's compatible with protools HD core PCI cards?
Thanks
Old 08-02-2008, 03:03 AM
Default
Bump bump bump
Old 08-02-2008, 10:01 AM
Smile
Can someone can help me?
Older Expansion Chassis Compatibility Question johnliquid Pro Tools TDM Systems (Win) 0 06-14-2012 12:38 PM
Expansion chassis compatibility? Armando Pro Tools TDM Systems (Mac) 2 12-18-2011 01:07 AM
Older mac pro w expansion chassis HD7 system vs 12 core mac pro & HD3 smokeydan Pro Tools TDM Systems (Mac) 9 08-01-2011 08:15 PM
Older Expansion Chassis HD2 Pro Tools TDM Systems (Mac) 1 12-29-2010 09:28 PM
New expansion chassis. Compatibility tests? Ang1970 General Discussion 1 01-16-2001 12:12 AM
