Splitting my hard drive to create an audio drive?
HI, GUY'S, I WAS JUST WOUNDERING IF ANY ONE COULD TELL ME HOW TO GO ABOUT SPLITTING MY HARD DRIVE TO CREATE AN AUDIO DRIVE FOR MY MUSIC FILES
THANKS |
Re: Splitting my hard drive to create an audio drive?
I would not recommend splitting a single drive as you want to, if performance is any part of your concern.
The reason you would split it is to provide a distinct backup disk for your audio projects or other relatively static file group vs your system files. I've done that in the past when I wanted a temporary backup partition until I moved the files off the computer. When you split a single disk, the drive heads have to work harder to cover the two partitions since they have to move further to get both system and audio files, and your performance will most likely worsen. Adding a 2nd hard drive would be - by far - the better option. There's nothing wrong with creating a separate folder on the system drive called "tempbackups" or something instead of partitioning. I believe Disk Warrier can do partitioning of a live drive without wiping out all data (someone else can probably verify that). Then, if you use the partition as a temp backup area, the drive heads will actually have to travel a smaller distance for system-level reads since your temp backup partition will not normally be read during a session at all.
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
As far as I know you either reinstall OSX, (and would need to have any important files backed up to somewhere besides the harddrive), then you can choose to partition the drive sometime during the setup. Or you can by software as mentioned above that will allow you to partion a drive with less chance of losing something important. Although I would agree another drive would probably be a better option.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
As cheap as drives are there no reason nor advantage to doing such.
Just get another drive. |
DAE can't get audio from hard drive fast enough, hard drive may be fragmented, there | huncke | Pro Tools TDM Systems (Win) | 6 | 02-23-2010 02:06 PM |
Cannot Create New Sessions because of Hard Drive? | JAO630 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-25-2009 09:06 AM |
Valid Audio Drive (hard drive issue) MacPro / HD3 | owenpop | Pro Tools TDM Systems (Mac) | 5 | 01-11-2008 12:28 PM |
Can't open or create a session on new hard drive | Pierre B. Samson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-25-2005 07:24 AM |
Hard Drive Performance Dual Processors and Dedicated Audio Drive | j_jayzatuc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-03-2000 05:52 PM |
