82 byte tokens?
Hi.
I just had a weird fatal error happen. I was playing a sequence on indefinite loop (it was looping for about 10 minutes) and I went into the other room. When I came back, I had a dialog window that states "protools has run out of 82 byte tokens". I pressed "ok" about 100 times but it just wouldn't stop coming up. I had to force quit. Any ideas on what this could be all about? -Jamey Protools HD v. 6.7cs4 G5 2x2Ghz OSX 10.3.7 1.5Gb RAM 96I/O |
Re: 82 byte tokens?
Do you have a Command 8 or a HUI? If so, hit the Answerbase and enter "tokens" in the search field.
Hope that helps, S..
"it's not about making the changes, it's about playing ideas in time" Scofield... |
Re: 82 byte tokens?
Yes, this is related to controllers. I'm checking some background.....
Are you able to get back to work at all? -tv
Tim vdB Avid Audio "There's a fine line between stupid and clever." |
Re: 82 byte tokens?
Hi.
Yeah, I'm back up and running. I'm only concerned because I lost a little bit of work from not being able to recover. Should have saved, but ah well. I made the text file as described in the answer base, so hopefully that won't happen again. -Jamey |
82 Byte tokens | filosofem | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-21-2007 01:59 PM |
OK ! So what is "PT ran out if 82 byte tokens" ? | priorytools | Pro Tools TDM Systems (Mac) | 2 | 01-04-2007 04:55 PM |
22 byte tokens? | rsgl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-22-2002 11:48 AM |
Out of 82 Byte Tokens | Davinci | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-04-2002 06:34 PM |
Out of 82 Byte Tokens | Davinci | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-03-2002 05:50 PM |
