Old 11-01-2020, 07:34 PM
audioluche audioluche is offline
Default Spotify, itunes, youtube in Pro Tools?
I was on a 5.1 mac pro and i always routed audio from these players in Pro Tools via optical out of the mac to the optical in of a 192 IO.
Now that i upgraded my computer to a new Mac Pro, i cant use this method no more to monitor or record audio from these sources into Pro Tools.
What is the best way to acheive this in 2020? Some software? Other internal routing?
I am on HDX, 2020.9.
Thanks!
Luc
Old 11-01-2020, 07:52 PM
Default Re: Spotify, itunes, youtube in Pro Tools?
You can't use software routing options like Rogue Amoeba Loopback with non-CoreAudio interfaces like HDX. You can add a small CoreAudio interface with optical out and use that into your 192 IO like you did on the old Cheesegrater... or use analog outputs into the 192, or switch the playback engine to Built-In Output for when you want to record that audio and use something like Loopback and just record directly into Pro Tools.. or some other DAW used just for doing that.
Old 11-02-2020, 03:11 AM
Sardi Sardi is offline
As Darryl mentioned, just grab a cheap interface with Optical out and continue as before.
Behringer makes some under AU$100 so it’s not gonna break the bank by any means.
Old 11-02-2020, 06:47 AM
jeam25's Avatar
jeam25 jeam25 is offline
Hi +1 for Loopback app here ... it is pretty good. I use it here and very happy with it.
Sent from my SM-G973U using Tapatalk
Avid Carbon Interface
Protools Ultimate
Old 11-03-2020, 05:17 PM
Thanks Darryl.
Too bad there is no software option working with HDX.
A small optical interface seems like a good solution.
Yep.
Maybe the easiest solution.
Thanks.
Old 11-03-2020, 05:19 PM
Yes, but it cant work with HDX...
You are using it with wich interface?
Old 11-04-2020, 08:41 AM
If you have a MTRX or MXTR Studio you can use Dante Virtual Soundcard to route system sound into DADman via Dante and set it up as a monitor source, or record it into Pro Tools. If you don't have MTRX or MTRX Studio, a small optical interface, as mentioned, is probably your best bet.
Scott Gatteño
Old 11-06-2020, 07:25 AM
Source Elements' Source-Nexus driver will do what you need - provides an AAX plug that will route from any coreaudio source into a ProTools fader.
http://www.richbreen.com
Old 11-25-2020, 12:20 PM
Hi Rich.
I did not seen your post before today.
I was ready to pull the trigger on a core audio interface, 300$ was the cheapest I found with optical out. I was revisiting this thread to be sure. Glad I did!
Source Nexus seems like the perfect solution for a HDX rig. I just sent my info for the demo.
Thanks for solving my problem!
Luc
How to get Mac (iTunes/Spotify) to play through HDX TurboD Pro Tools 11 2 06-21-2017 08:47 AM
itunes, spotify PC sound with HD OMNI and 12.7 stevedresser83 Windows 1 04-22-2017 09:04 PM
Installed PT 11 Now iTunes, YouTube, Premier, FCPX Freeze cjtowner macOS 5 08-26-2015 01:02 PM
High Quality for Spotify etc bryced87 macOS 3 02-21-2015 01:15 PM
Loudness for Spotify Advertise zzstation Post - Surround - Video 4 11-16-2014 12:33 AM
