Plugins Jacked Up
Seems that my plugins within Audio Suite and on the inserts are not where they're supposed to be For example the Pitch Shift area has the wrong stuff and no Pitch Shift plugs. Any explanation? Specs are: Pro Tools LE 8.0.1, Mac OS 10.5.8 with Mbox 2 Pro on a 2.66 GHz Dual Core with 7 gb of ram.
Thank you, SPC |
Re: Plugins Jacked Up
Maybe try resetting the plugin sorting under the preferences window? Or maybe you have an older version of that plugin that does not recognize the sorting setting in PT8.
Check the plugin compatibility grid. It's most likely that some plugs are not compatible.
Also, the jolly joker= trashing prefs & databases!
my blog:Tamas Dragon |
Adjusting those settings work but to be specific, I can't seem to find Audio Suite > Other > GAIN or REVERSE (I really need these back!). I also don't see the general PITCH SHIFTER in it's folder anymore. The Pitch Shift folder only has mono and stereo Doublers - 2s and 4s. Those two seemed to have disappeared! Any thoughts?
Thank you, SPC |
That's odd for sure. Either operator error or maybe re-install PT. I find GAIN and REVERSE right where they belong on my 8.0.3 setup
jacked up my pt le 8.0 for win.xp | gfunkateer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-30-2010 08:35 PM |
HELP! mix sessions all jacked after reopening PT 6.4 | Barry Weeks | Pro Tools TDM Systems (Mac) | 2 | 03-17-2008 02:38 AM |
7.1 MIDI jacked up after working in 6.9 | BookSix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-14-2007 11:18 AM |
midi is jacked up in the new 7.3.1 update | 7599 | MIDI | 2 | 02-07-2007 06:50 AM |
my bounce files are jacked up | phatboybeats | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-13-2004 11:47 PM |
