what\'s the skinny with Appletalk?
Does, leaving it on, still mess with PT? and how so?
I work with it off. I know I can disable the omf waring but I would like to know if Digi still remains cautious of Appletalk being left on while working in PT thanks scott
[img]/images/graemlins/tongue.gif[/img] <<<<< in the psychiatric emergency handbook this is bad news. |
Re: what\'s the skinny with Appletalk?
When you're doing high performance audio, you should leave your network settings off. We don't even have our PT-rigs networked since we have removeable drives at each station, but I have quite a few clients that do have them networked. With Appletalk turned on, you're allowing any other computer on the network to contact it whenever it wants to which can interfere with the stability of the system... this isn't just a ProTools thing but any audio application. Just a good idea not to have it on while working. When you need to move files around, then obviously turn it on but remember to turn back off before you start working....
We leave apple talk on. We don't have problems. We have been using appletalk for years.
We use appletalk to file share between control rooms and a file servers that store SFX or distribute our work on the internet. I'm sure it is probably better to have appletalk off, but from a practical point of view, it works. [img]images/icons/smile.gif[/img] Roy Machado Dallas Audio Post Group
Roy Machado Dallas Audio Post |
Consider yourself lucky.... ;-) Had a client lose a project because it was left on but that is also rare.... if it works, hey... leave it on. Back to Nyquil land ;-( I was so sick the other night that I was errrr well, what you do when you're sick, it caused a couple of blood vessels in my head to break open! ;-( At least I can see again though ;-) Medication is gooooooood wooohooo Sorry, meds talking again...
When you launch PT with AppleTalk enabled, it is actually OMS that gives the warning that AppleTalk is on and "makes MIDI less reliable," so I would say, if you are doing MIDI with Pro Tools, turn AppleTalk off.
We use Appletalk over Ethernet, and have for years, with no ill effects whatsoever. If you use DigiStudio (which I got a demo of the other day and was very impressed with), it's a must.
We do keep file sharing off so that the machine doesn't appear on the network for someone to log on to. We can log on to other volumes if we want to, as long as those remote machines have file sharing turned on. JK |
Oh, yeah, by the way, if you use Appletalk over Ehternet, it shouldn't mess with MIDI over your serial ports. We have noticed no effect on timing (or anything else.)
Of course we're not running 128 channels of flat-out MIDI, either, so YMMV. JK |
in modern mac os (since 8.6?) oms seems to be operating on a different plane than appletalk. we run all our systems, heavy with midi/video/audio, with appletalk on, sharing each others drives. you do need to watch how many people you let on to your system at a time, and if someone is gonna copy over a 200meg file they should let you know first!
all in all it is awesome. for the transfering REALLY big files we use...........our iPods! [img]images/icons/grin.gif[/img] |
Yep, we too do heavy midi,audio, and video with appletalk on, in several rooms, never a problem.
I often have email running...but i am a cowboy! mesh |
Here is the skinny on UA plugins ... | Southsidemusic | AAX Plug-ins | 8 | 07-09-2013 10:47 AM |
What's the skinny on RAID? | Martin Vipond | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-03-2003 08:14 PM |
Skinny on Reason | bassbuddy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 12-22-2002 12:48 AM |
The Skinny on ProTools HD | mazuroo | Post - Surround - Video | 0 | 07-08-2002 12:13 AM |
What's the skinny on SCSI? | Michael Cottrell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-06-2002 02:38 PM |
