Old 02-02-2018, 11:56 AM
neil99 neil99 is offline
Default Can’t hear MacBook through headphones
Hello, first post here and I’m very sorry if this is deemed a dumb question but not sure where to turn. I just got the eleven rack, works fantastic love the sounds but should I be able to hear music in iTunes through the headphone out on the elevenrack or do I need a small mixer?
Old 02-02-2018, 01:19 PM
Pingafuego Pingafuego is offline
Default Re: Can’t hear MacBook through headphones
Are you able to hear music in iTunes through monitors connected to eleven rack?
Make sure your headphone output is not muted.
Old 02-02-2018, 02:16 PM
I dont have regular monitors hooked up, I am only using the headphone out on the eleven rack unit. The headphones work fine, wondering if the usb from macbook to elevenrack is strictly for control or does it pass audio from the mac to the unit as well.
Old 02-02-2018, 02:56 PM
Cowboy Bob's Avatar
Cowboy Bob Cowboy Bob is online now
Have you got the current driver installed?
Does the Eleven Rack editor work on your system?
"If the grass looks greener on the other side of the fence, well, it is likely due to the amount of manure being spread on that side of the fence." Cowboy Bob
Squaw Creek Road Studio
Bob
Pro Tools Ultimate (2024.3.1)| Pro Tools Carbon | Sibelius Ultimate (2024.3.1)
M2 Max Mac Studio w/64GB RAM | 1TB SSD | Mac OS 14.4.1| (Main Rig) |
3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Ventura 13.3.1 |
Avid Eleven Rack ERXP | Focusrite Clarett 8Pre X |
Old 02-02-2018, 03:00 PM
im pretty sure I have all the most updated drivers installed, and yes the editor works fine on my mac, thanks!
Old 02-02-2018, 04:30 PM
Sardi Sardi is offline
Obvious question - do you have the sound output in system preferences set to your Eleven Rack?
Old 02-03-2018, 06:14 PM
Yes I have set the output to the eleven rack,
Old 02-04-2018, 10:46 AM
The Eleven Rack has multiple volume levels that affect things, including a head phone volume. You should read about all those in the Eleven Rack User Guide. This is a common reason for folks not hearing stuff in headphones.
On the Eleven Rack Front Panel if you scroll the display to the far right when looking at the Rig View you will see the level meters, they are very useful for seeing what is happening with input and output signals. If you can’t find those then again, the User Guide will help you.
Still stuck, then clear info needed... computer and OS version, driver version, Screenshots of relevant computer audio setting panels, description of headphone and master volume, descriptions of what you see the Eleven Rack meters doing etc.
can't hear my synthesizer through my headphones marieanne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-30-2010 07:42 AM
Cannot hear Pan in headphones John V. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-15-2007 06:14 AM
Hear the input on headphones? possumday Pro Tools M-Powered (Win) 1 10-05-2007 08:04 PM
Cannot hear what is being recorded in headphones Andre White 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-16-2007 07:26 AM
I want to hear metronome in headphones only... DanZ Pro Tools TDM Systems (Mac) 4 10-07-2006 10:10 AM
