PT 12.7.1 and 12.7 bouncing and opening issues
I created a case for this but we all know how long that takes. I'm on a Mac Pro 6 core, 32 gigs of RAM, 10.11.7? and PT 12.7.1 and/or 12.7 with PTX mixing television. My template has not changed in months, my plug-in's have not changed and they are fully updated. I've had two issues and I'm wondering if they're drive related. This is the error I get..
"Unable to bounce offline. Error while preparing: "Assertion in "/Volumes/Development/200028/ProTools/NewFileLibs/SMgr/SMgr_StConnectionPrep.cpp", line 73." ... Do you want to do a real time bounce instead? So sometimes I'm able to open, work and bounce but only once. Never twice without closing the session and re-opening. Some other times I work and then try to bounce and get this error... "Could not complete the bounce to disk command because vector" Sometimes I work, then close, then I cannot open. I think I've tried most things. I cleared all unused clips and tracks. No luck. I copied the session to a different drive, same issues (which makes me think it's not a drive issue). I did a save session copy, same issue. I moved from PT12.7.1 to PT12.7, same issue. The only thing that worked was creating a new session with the exact same template, re-import everything and then I'm able to work and bounce, but again, only ONCE. I am mixing televison so I have an AAF created from Media Composer v 6.6 and always a high rez ProRes video in the session. |
Re: PT 12.7.1 and 12.7 bouncing and opening issues
I'm having this problem again with a session. I had it once before and traced the problem back to a file with an invalid character in the name. When I renamed and re-imported that audio file, I was able to bounce again.
This time, I have a different cause. No file name issues. I'm using a template that I have used to mix this TV series for 2 years, and suddenly today I cannot output the current episode. I'll let you know if I figure anything out. What I do know Is I can bounce my masters individually by left clicking and choosing BOUNCE from the context menu. That has been my workaround to finish the project. Bouncing each stem offline individually. |
Bouncing Issues | McLuckie | Pro Tools 9 | 7 | 04-12-2013 06:51 PM |
Bouncing issues | pjmusiced | Windows | 0 | 05-04-2012 12:13 AM |
How do I keep iTunes from opening after bouncing a QT? | rhumphries | Post - Surround - Video | 13 | 03-12-2012 01:45 PM |
Bouncing Issues | benplaysmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-31-2011 10:00 AM |
Bouncing Issues...SERIOUSLY?!?!?! | mforehand | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-10-2007 12:59 PM |
