Old 02-14-2017, 10:49 PM
bspaceman bspaceman is offline
Default ProTools 12.4 Multiple Errors....help!
Hey folks,
This may have been covered, though I did a search and could find very little here.
I am receiving multiple errors when attempting to launch ProTools 12.4 on my macbook pro.. These errors include:
"Could not create the TCE plug-in's factory default file because the plug-in doesn't support the current sample rate".
"Could not create a new document because Assertion in "/Volumes/Development/158347/ProTools/DFW/Views/UMenu.MacOS.mm", line 1624".
The current playback engine does not support a sample rate of 0 kHz.
Additionally, my MBox Pro III is not being recognized byProTools.
I am running OS X El Capitan version 10.11.6, which is supposed to be supported, on my mid 2014 13' retina MacBook Pro. 2.6 Ghz Intel Core i5, 8 GB 16000 Mhz DDR3 ram.
I just checked and this is what I see under "Thunderbolt":
Vendor Name: Apple Inc.
Device Name: MacBook Pro
UID: 0x0001000F07D6C490
Route String: 0
Firmware Version: 17.2
Domain UUID: 781410B8-CC83-DF53-BFC4-2A386D00FC64
Port:
Status: No device connected
Link Status: 0x7
Speed: Up to 20 Gb/s x1
Current Link Width: 0x1
Receptacle: 1
Link Controller Firmware Version: 0.11.0
Port:
Link Status: 0x7
Receptacle: 2
I have a firewire to apple OEM thunderbolt adapter running from my black OEM cable to my computer. Is it possible this could be the issue? i see no damage to either cable.
I tried trashing audio core plug-ins and protools preferences to no avail.
I have the MBox Pro Preference panel open and I can see that I have package 1.3.5 but there is nothing showing for firmware. I reinstalled the latest driver from the link here: http://avid.force.com/pkb/articles/D...ox-Pro-Drivers
Any help would be greatly appreciated.
Thanks!
B
Old 02-16-2017, 09:44 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: ProTools 12.4 Multiple Errors....help!
Try holding down the N key while PT is loading. This will allow you to re-select your interface for the Playback Engine. After selecting your interface, I would recommend going into the I/O settings and default your inputs, outputs and busses.
Will
System Details
Old 02-16-2017, 01:25 PM
Thanks for your reply.
I have done that and it's still not showing. I've restarted, held N a few times to no avail.
I can hear my computer and iTubes through the interface though, just Protools software isn't recognizing the device.
Old 02-16-2017, 02:08 PM
Top Jimmy's Avatar
What happens if you switch the MacBook to its internal audio ins/outs and only use the Mbox for Pro Tools?
James Cadwallader
Old 02-16-2017, 11:06 PM
Thats just it. The computer isn't seeing the MBox at all. in my Audio MIDI set up it shows Built-in Mic, Built-in Output and Pro Tools Aggregate I/O. The PT Agg has 0 in/0 out and says "no Devices in Aggregate. I just did a clean install of Pro Tools 12.5 and still nothing, same errors.
I'd really like to get to working again. This is beyond frustrating.
Old 02-17-2017, 12:00 AM
Top Jimmy's Avatar
Any chance you mistakenly installed the Mbox driver and not the Mbox Pro Driver?
http://avid.force.com/pkb/articles/d...ox-Pro-Drivers
James Cadwallader
Old 02-17-2017, 12:03 AM
Top Jimmy's Avatar
Nevermind. I see you have the right link in your original post.
Try to find a way to test the thunderbolt-firewire adapter. Maybe see if it works with a firewire drive or something. This should help determine if it is working or faulty.
James Cadwallader
Old 02-17-2017, 12:45 AM
I will certainly see what I can find.
I should also mention that upon checking my Avid CoreAudio Manager I see the following:
Avid HW: Unsupported Device
Status: Not Connected (HW not found)
Channels: N/A
Buffer Size: 512 (Greyed out)
Old 11-01-2017, 11:42 PM
Just wanted to updated this from a long while ago. It was my adapter cable. Once I replaced it, everything was all good. Just thought I would help in case others experience this in the future.
Old 11-02-2017, 08:05 AM
TOM@METRO's Avatar
Thanks for the update.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
HELP! M box 2 multiple errors with pro tools 10 Fyenamuzik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-06-2013 12:43 PM
Multiple 6101 errors scott bourgeois Pro Tools M-Powered (Mac) 2 04-03-2012 07:31 PM
Help - multiple errors with PT7, PT8, 002 and MBOXPRO2 (XP) Skip Regan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-22-2010 02:56 PM
Multiple errors/issues in PT LE 8 Big Blue Barry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-27-2009 08:42 AM
G4 Bus Errors with Multiple Monitors steve-o 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-08-2000 08:40 AM
