toggle edit/mix window
Is there a shortcut for that? ...I seem to recall ctrl + = ...but I can't find it now, and I think I didn't get it to work.
Re: toggle edit/mix window
Yup, Cntrl and + simultaneously.
Phil O'Keefe PT 2023.6 Ultimate (Perpetual) | Avid Carbon | M1 Max Mac Studio; 32 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. PT 2023.6 Studio (Perpetual) | M1 MacBook Air; 16 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. |
I have the latest M$ 5-button Intellimouse. With the software you can program the wheel button and the two side buttons to perform different functions in different programs. I've programmed ctrl/= into the left side button. Works a treat.
You might say I "Have the situation right under my thumb!" [img]images/icons/rolleyes.gif[/img] Groan. Mark
http://www.oneearthproductions.net |
For those who don't own this mouse yet, get it. It is the best thing that has come along next to WinXP. Microsoft Intellimouse Explorer. Don't get the wireless version!! You can purchase a USB to PS2 mouse adapter from www.newegg.com and I'd recommend using the PS2 mouse input instead of USB. Not only is it great for shortcuts, but it makes pointing a breeze and is super fast and accurate. Allen [img]images/icons/grin.gif[/img] |
It doesn't work for me. Maybe it has something to do with me having a Swedish keyboard. [img]images/icons/rolleyes.gif[/img]
There's a tricky thing with caps lock using CTRL =.
I can't remember which one (caps lock ON or OFF), but I think one of them doesn't work. Of course, the other does... Hope this helps, Cheers |
I have a norwegian keyboard, and this is the trick to make it work on a non-english keyboard:
1 You need to set your language to english in windows. I have it set up so that I can switch between Norwegian and english by by pressig alt+shift. 2. You need to figure out what key on your non-english keyboard that correspends to the = key on an english keyboard. On a norwegian keyboard this is the + key on the alpha keyboard. This way you can also zoom in/out using the keys that correspends to the [ and ] keys on a english keyboard. ( on norwegian and swedish keyboards this is the å key and the key to the right to the å key) Good luck and hope this helps! Espen
IMDB |
Ok, so I've tried it all...changing to english keyboard, both American and British, caps lock on and off...nothing works... it's not a big deal really, but it'd be nice if it worked. I'm a lazy person [img]images/icons/grin.gif[/img]
Command+Shift+0 on MacBook Pro not toggling between Edit & Mix Windows | clausiii | Pro Tools 11 | 80 | 12-19-2017 06:19 PM |
Mix/Edit does not toggle Win7 PTHD | digidesigner | Artist Series | 5 | 08-30-2011 08:04 AM |
Toggle Mix and Edit windows | michaelm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 06-15-2010 07:49 PM |
Toggle mix / edit window with MightyMouse ? | T-Low | Pro Tools TDM Systems (Mac) | 5 | 12-28-2009 06:42 AM |
toggle mix and edit window shortcut | daven | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-02-2005 02:02 PM |
