Where's my Elastic Properties?
Mac 10.5.8/PT8
Never used it before so perhaps I'm missing something but it appears that my Elastic Properties may not be installed even though it exists in my plugins folder. symptoms: When I right click on a selected region there is no Elastic Properties... Conform to Tempo etc. section in the drop down menu. There is also no menu in the edit window track list (next to the samples/ticks button) to select a property that will enable a track with Elastic Audio. It's just blank. Am I being obtuse?
Mac Pro 2x3.46 Ghz Dual 6-Core Intel Xeon 64 GB Ram OSX High Sierra 10.13.6 PTLE Subscription - pending Interface - pending Midi Controller =M-Audio Axiom 49/USB2 |
Re: Where's my Elastic Properties?
see if this can help. YouTube - Pro Tools: How To Use Elastic Audio
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Any Help would be greatly appreciated. ***UPDATE: The problem seems to be isolated to the session in question because the EA properties do appear in other sessions. Also I just noticed that "Enable Elastic Audio on New Tracks" in Preferences/Processing is greyed out and not selectable!
Workaround
Here is the workaround if you find yourself with SDII tracks:
Save the session as a copy changing the audio format from SDII to WAV. This solves the problem. EA appears as normal in that new saved copy. I came across this solution in this thread: http://duc.digidesign.com/showthread...+Elastic+Audio Turns out it's in the PT8 Manual on page 247.
Oh no! SDII ruins our globe! Convert it asap!
my blog:Tamas Dragon |
Re: Workaround
I consider it a workaround if your stuck working with an old session that was recorded in the old format SDII. We shouldn't just trash old audio files just because they're legacy right?
Elastic Audio Properties not working - 10.3.7 / 11.0.2 | A Chapman | macOS | 0 | 12-02-2013 05:35 AM |
Elastic Properties - from PT8 to PT7.4 pitching | Farmer Dave | Pro Tools TDM Systems (Mac) | 1 | 01-31-2010 12:16 AM |
Elastic Properties | lalalandguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-20-2009 05:20 PM |
No Elastic properties in 7.4 | xxicjoy | Pro Tools TDM Systems (Mac) | 2 | 02-27-2009 01:44 PM |
Elastic Audio Properties | Weirdness | 25ghosts | Pro Tools TDM Systems (Mac) | 11 | 04-08-2008 09:35 AM |
