Re: Midi Responce
OK, first set up Triton in OMS then create a Midi track in the Mixer and 2-track channels( these will be your audio inputs l&r). On the MIDI track, choose the Triton from the offered selections. Then scroll to a midi channel. You can then put Midi into record and you can monitor through the 2-audio tracks( they must be set to record also to hear audio) Later, you may choose to record the synth's audio playback after you've done any editing(MIDI). This is a very general description so if you have further questions, you should check the Operation maual or the PDF menu.
Armando |
Midi Responce
I'm using pro tools 5.0 and I'm trying to record MIDI... I 'm using a triton for the main source directly to the interface digi 001. I get signal in but no sound out, What do I need to set pro tools to and what do I need to set the triton to for send and recive. I am also trying to use cubase for recording MIDI but have had no luck with that either. I also have micro Logic, is Logic easier? somebody please help me...
Thank you Cloud 71 |
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input | yellow | Eleven Rack | 1 | 05-04-2012 03:33 PM |
003 midi ports not there in midi studio setup? Unable to record midi now? | TREBLEBLEED | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 12-22-2009 12:06 AM |
MIDI Questions On IMPORTING MIDI & Recording MIDI Pro Tools LE 7.4 | Michaeldante | MIDI | 3 | 03-27-2009 05:42 PM |
Message/responce for member "SNAPPER" aka John. | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-10-2008 07:08 PM |
System responce is very slow | Jstil | Pro Tools TDM Systems (Mac) | 4 | 05-02-2007 01:33 AM |
