Old 08-24-2003, 03:55 PM
poppo poppo is offline
Default PCI Breakout box and the G5
Has anyone thought about using a PCI breakout box with the G5? Is this possible and could this be a work-around to the PCI voltage issue? Just a thought.
Don't do it for the reward. Do it for the sake of doing it.
Old 08-24-2003, 06:54 PM
soundsession soundsession is offline
Default Re: PCI Breakout box and the G5
Hey man,
You don't specify want you want to record, and how many inputs you need to record at once. If you running logic or cubase....any MOTU system will be cool as the PCI card will work with either. The systems are really reliable and user friendly (if you doun't wanna get too technical), and reasonably priced as well.
Hope this helps,
If you need more info, check out the website...motu.com/
laters
Old 08-24-2003, 07:02 PM
kmshroom kmshroom is offline
most (if not all) MOTU cards will NOT work with the G5, because of the different voltage. hence the reason MOTU is providing hardware exchanges, similar to Digidesign (with the 002's).
you cannot find peace by avoiding life
Old 08-25-2003, 01:24 PM
Lucky Lucky is offline
FYI
SBS PCI expantion chassis already use a 3.3 volt PCI card. They will work with the new G5s. As for the PCI cards to put in the chassis.....
does 001 work without the breakout box? kmshroom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-01-2003 07:54 AM
please help with breakout box prob agent fu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-19-2003 03:33 AM
Can you run PTLE without the Breakout Box??? mattm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-13-2002 12:49 AM
Breakout Cable gerax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-06-2001 06:52 AM
888 to 01V 25pin to AES-EBU breakout box Tips & Tricks 0 10-08-1999 11:54 PM
