Old 12-23-2018, 05:41 PM
jphaudio jphaudio is offline
Default Dither-Resampling
I read some of the dither posts and still have a workflow question, if anyone can help or advise. When working in 48k/32bit or 88.2/32bit I have tried the Waves Limiter Ultimate with bit depth reduction, Sonnox Limiter, Elixir v3 limiter, but still have a lot of unknowns.
The thought was to print my tracks at the same session settings and then import the audio file into RX7 to dither and then resample for CD/Cloud. Should I do this as a regular method? In RX7 should I resample down to 44.1 first then dither or vise versa?
I always just bounced to disk for the final format, but now see that I need a better way to get to from high res to final format.
It seem that the RX7 method preserved the headroom in the mix though.
Any suggestions on resampling down from 88.2 to 44.1 for the final product, and which step to do first, dither, or resample would help a lot.
thanks
Old 12-23-2018, 05:56 PM
Default Re: Dither-Resampling
It makes no sense to dither then resample. Dither should be the last thing done.
Old 12-23-2018, 06:00 PM
What would be best? Resample in PT, or RX7, or Ozone8. Too many options.. thx!
Old 12-23-2018, 06:08 PM
I have no idea, I'd not care much, or use whatever is at hand. Others may have stronger ideas.
Old 12-23-2018, 10:52 PM
BScout BScout is offline
Resample and dither (that order) in RX7
Izotope's resampling is better than almost anything else out there and has controllable filters (steepness and therefore the effect of pre-ringing at the cut off)
And, of course, dither should be the very last process right before bit depth reduction. RX7 has multiple shaping options but that's really up to you.
Old 01-10-2019, 10:52 PM
Thank you....sorry for late reply, vacation
Sent from my SM-N960U using Tapatalk
Bitrate Resampling Question Cayce 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-18-2011 11:45 AM
How can you eliminate bleed when recording drums? resampling? Help please! xstortionist General Discussion 28 10-08-2009 11:15 AM
ReSampling StainedClass Pro Tools TDM Systems (Mac) 2 06-20-2003 06:53 PM
how to do just resampling? cedmonds General Discussion 4 01-30-2002 11:31 AM
how to do just resampling? cedmonds Digidesign Hardware & Software 2 01-25-2002 01:54 PM
