Old 04-26-2009, 04:09 AM
mattrixx mattrixx is offline
Default Track Record Enable KC
Hi all,
I have a pretty lame question I haven't been able to find the answer to.... What is the key command for Record Enable/Disable of the currently selected track?
Ultimately I would love it if you didn't have to enable it at all.... ie Like Logic does with audio tracks. For example:
If I am on an audio track in Logic, with a valid input channel and hit record, it automatically goes into record, at the channels assigned record level (and records of course).... and then when I hit stop, it is out of record and the fader goes back to the playback set level.
I know that ProTools has independent record and playback levels per track, but i am sick to death of the "There is no track record enabled" error message.... Wouldn't it be good if it just recorded!!
BTW, after a bit of a hiatus from ProTools (at least any serious music stuff), I have been loving the 8 version and all the Elastic, Air and other niceties....
Just trying to adapt my very fast Logic workflow to ProTools.... Dynamic TRansport has gone someway to doing this, but still trying to push the envelope.
Regards,
Matt
[note the is cross posted from BigBlue Lounge]
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 04-26-2009, 04:20 AM
Default Re: Track Record Enable KC
Whoops... Shift + R
Matt McKenzie-Smith
mattrixx.net
Old 04-26-2009, 06:58 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Originally Posted by mattrixx View Post
Whoops... Shift + R
Chinese man say "U gossett"
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
PT 10 Audio track will not record enable brethart Pro Tools 10 3 06-25-2013 05:58 AM
Cant record enable more than one track at a time Aikoaiko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-19-2012 02:55 PM
can't record enable a track macfreak86 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-11-2011 05:11 PM
When I enable a track to record and then hit 'play' the track will remain silent Rainerbird Pro Tools M-Powered (Win) 2 08-07-2009 09:41 PM
Can't record enable track in DP 3 clockface 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-29-2003 11:05 AM
