Old 07-25-2008, 11:30 PM
emf1138 emf1138 is offline
Default Video Game sounds
Anyone know of a synth or plug-in or some kinda procedure or some website where I can emulate/or learn to emulate classic video games sounds? Like sound effects like from the original 8-bit NES or older Atari games even.
Eric Freeman, CAS
Sound Supervisor/Re-Recording Mixer
Disney TV Animation
IMDB
LinkedIn
Old 07-26-2008, 09:28 AM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Default
Eric,
If it helps, I have the original NES 8 bit sounds as wavs.
How do I get them to you.
Old 07-26-2008, 12:16 PM
audiogeekzine audiogeekzine is offline
Default
Many of the Tweakbench effects and instruments are designed for this
http://www.tweakbench.com/
Peach, Toad and Triforce say Nintendo in the description so I'd start there.
@theaudiogeek
| www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com |
Old 07-26-2008, 04:26 PM
Default
Thanks for the replies guys! Can the files be zipped and just emailed? They small enough? If not, contact me and I can setup a digidelivery. Also, are there any legal issues in using them for broadcast projects?
emf1138@yahoo.com
I looked at the tweakbench stuff and it sounds perfect, though it looks like it's Windows VST only. I'm still on an ancient G5.
Eric Freeman, CAS
Disney TV Animation
IMDB
LinkedIn
Old 07-27-2008, 04:22 PM
Default
Eric
Check your email.
As I wrote in the email these were ripped directly from NES ROMS, does that make them legal??
I would think not!!!
We all used them with MAME years ago.
Old 07-28-2008, 05:49 PM
Default
Found this, Magical8bit, it's a Mac AU version which works great!
http://www.ymck.net/english/download/index.html
Eric Freeman, CAS
Disney TV Animation
IMDB
LinkedIn
Old 12-03-2008, 08:30 AM
fooloof fooloof is offline
Default Re: Video Game sounds
Hello, Eric (or anyone else knowledgeable on the subject). Tried to PM you but apparently that function has been disabled. I also found the Magical8bit link but do not know how to use it in PT. I have a PPC Mac. The instructions say to put it into the following folder (HD-library-audio-plugins-components), which I did. After that, the only thing I knew to do was try to bring it up in PT by opening the inserts and looking for it in the instrument menu (where my Reason plugin is). It wasn't there or in any of the other insert menus (such as EQ, Dynamics, etc.). Is there something I'm doing wrong. Thanks in advance for the help.
Fooloof.
Old 12-03-2008, 12:24 PM
It doesn't come up as PT plug in. I actually used it via Garageband and routed the output of that into PT tracks. It works via Logic as well, if you have that available. Unless their gonna develop and RTAS version (which most likely ain't gonna happen) these seem to be the only options. Hope that helps!
Eric Freeman, CAS
Disney TV Animation
IMDB
LinkedIn
Old 12-03-2008, 12:41 PM
IO Composer IO Composer is offline
There's a fantastic SID chip emulator that I use all of the time called QuadraSID. You'll need to use the vst to rtas wrapper to use it in protools, but it's totally worth it.
Cheers,
Jamey
Jamey Scott
Dramatic Audio Post, Inc.
Burbank, CA
IMDB
Old 12-05-2008, 09:45 AM
epm epm is offline
i've used Magical8bit on a few things via garageband as well, and it works great.
-Evan
HTML code is On
Sound, game and Video is OFF... GW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-05-2007 01:12 AM
Video Game Audio astralboy Post - Surround - Video 3 03-10-2005 12:48 AM
OT: First Video Game gig! vocalvoodoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-19-2003 10:22 PM
VIDEO GAME music VincePro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-23-2002 11:23 PM
computer/game sounds thru 001 David Hardie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-18-2002 05:08 AM
