Old 11-16-2010, 12:01 AM
Jepse Jepse is offline
Default Pro Tools not playing all midi notes
I programmed a midi drum pattern for song, and am using Reason Drumkits in pro tools. The problem: Not every midi note will play and it can change every pass of the midi region. So for example, in one bar it may miss playing the kick drum, in another the hi hat. The notes are showing, the velocity, volume etc. is fine, but it is literally hit and miss as to which notes will play during a pass of the song. It is as if the song jumps pass a midi note every now and then.
I have increased the HW Buffer, Playback buffer and cache size all to no avail. I can't figure it out. Any thoughts?
Mac 1.8 Dual 5 Gig RAM (OS 10.4.11)
Pro Tools 7.4
002R
Reason 3.05
Waves Platinum
MacBook Pro 2019 15 inch 32 GB RAM
Pro Tools 19.6
Apollo X8P
RPQ2 Stereo PreAmp
Some Analog Gear, Various Mics
Guitars, Electric, Acoustic, Piano
Old 11-16-2010, 02:23 AM
tobbenos tobbenos is offline
Default Re: Pro Tools not playing all midi notes
Occasionally, I've encountered the same problem. I don't know what the solution is. Don't know about you, but for me it happens mostly when the midi notes are close together, like a pumping bass or something..
midi notes not playing back properly guitarhead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-21-2013 12:40 AM
Midi chaos (playing notes on its own) Ryan Young MIDI 11 05-13-2009 01:20 PM
Midi notes keep playing jallen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-28-2008 09:30 PM
first MIDI notes not playing when starting playback levelaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-17-2008 11:10 PM
MIDI records two notes when playing one 2A Batterie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-13-2004 09:22 PM
