Mbox Mini 2 Sound Recording Problem
Hello,
I recently bought a Mbox Mini 2 and installed the Protools LE 8 software on my computer. I have the instrument input (guitar) set up correctly, and on my computer I even see the midi input levels jumping up almost to red before I record. Every time I record, I see the midi input changing, and I can even hear it through my headphones, but protools doesn't record anything. It simply records a blank space with absolutely no volume or input. I don't use an external hard drive. Is this the reason? Thanks kindly, Rebornalphawolf |
Re: Mbox Mini 2 Sound Recording Problem
You have to record to an AUDIO track!
Your guitar is mono audio!
002R BLA mod and Mbox mini 2, PT 11.3.2, HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive |
If you are new to PT's, you might not realize that both the track, and the transport must be record enabled! Record enabling just the track, will only alow you to monitor your playing. If recording to an audio track also, then obviously all 3 would need to be red! (The transport is at the top, or can be brought up with Alt + 1 on the number pad). You will have to get a 2nd drive to have any real success with any DAW, but I doubt it is your prob just to record??!!
Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 | |
I had and have both audio tracks enabled for recording.
Thanks, I'm very appreciative for any advice! |
It works now! Thanks for the audio track tip. Man this software is a little touchy I have to admit! haha thanks :)
MBox 2 Mini Recording Problem. | Geron330 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-16-2013 01:21 PM |
Trouble recording with mbox 3 mini (sound seems to work but can't record it) | Vince6700 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-10-2011 07:20 AM |
MBox 2 mini recording problem | ryan2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-25-2009 10:36 AM |
MBox 2 mini recording problem | ryanp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-25-2009 09:37 AM |
No "Sound Recording" option with Mbox 2 Mini | ev_wagner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-04-2007 09:38 AM |
