Old 07-28-2017, 05:40 AM
JulianMartin JulianMartin is offline
Default Problems with 11R noises + editor
Hi there !
I'm facing a few problems with my Eleven Rack.
When I record in Pro Tools, I hear a "screetch" noise, every 2 or 3 seconds. Very regular.
I guess that's a sync problem ?
I plug the SPDIF into a Fireface 400
And USB to an iMac OSX Yosemite 10.10.5
Plus the Avid Eleven Rack window in the System Preferences says the device not connected. But it is !
And at last the Editor runs, but the window doesn't appear on my screen...
Are all these problems from the USB connection ?
What can I do ? I tried the things I know but nothing worked so far !
Of course everything is up to date.
Software 1.2.12
Firmware 2.0.1 Build 0.1.5.7
Thanks
Old 07-28-2017, 07:47 AM
panamajack's Avatar
panamajack panamajack is offline
Default Re: Problems with 11R noises + editor
Originally Posted by JulianMartin View Post
. . . When I record in Pro Tools, I hear a "screetch" noise, every 2 or 3 seconds. Very regular.
You will need to connect SPDIF cables in both directions and manually set up one of the two devices to be the master clock for the other.
When using the 11R connected to another inferface by SPDIF, the USB connection is not carrying audio, but will let you control it by way of the standalone editor.
The Pro Tools settings for I/O will be different than when the 11R is the interface when your main interface is the Fireface 400.
Might want to mention what version of Pro Tools you are running...
PT10.3.10HD(Tyan s2932 [8core Shanghai 2.7GHZ] 32GB,Win7 SP1); PT10HD(Tyan s2892 w/10GB, Win7 SP1);PT8HD(Dell 690 quad Xeon 3.0, 8GB, Win7,192 I/O, 96 I/O);MacBook Pro: 11R, Apogee Element 46, Focusrite 8PreX PT HD 11.3.2; Mac Pro 3.47 Hex 32GB, OSX 10.12.6/L10.4.2;L9.1.8, 2.64TB; G5 D2.3 4GB, 10.4.11/L8; 12c MP 2.66/32GB PT12.4; Structure, GigaGS3, Kontakt 5, Garratin, Sibelius 8.7+, Finale26,EMU,Vegas Pro 16-10/; RME HDSP9652,MOTU 2408 MKIII/1224/308, FX,Kurz,L5s,Strat,ASAT,JB,Zon
Old 07-28-2017, 10:55 AM
You do not need S/PDIF cables going both directions (only if you want to reamp).. Just from the Eleven Rack to the Fireface, and make sure the Eleven Rack is set to clock internally and the Fireface set to clock from S/PDIF.
Keep things as simple as possible, and debug one thing at a time. S/PDIF clicking and similar noises from clocking issues has nothing to do with USB or the control app, disconnect all that and use the front panel options on the Eleven Rack to get this working then later you can futz with whatever you want to do with that other stuff (you need to disconnect the USB cable to get full control via the front panel user options menu, so do that now).
If that does not fix it then it may be some other issue, post a recording of the noise you get online so we can listen to it.
Old 07-28-2017, 08:42 PM
Goobs's Avatar
Goobs Goobs is offline
Originally Posted by Darryl Ramm View Post
You do not need S/PDIF cables going both directions (only if you want to reamp)...
Or, if he wanted to slave the Eleven Rack to the Fireface's word clock periodically for testing.
iMac (Retina 5K, 27-inch, Late 2015), 4.0 GHz Intel Core i7, 32 GB 1867 MHz DDR3, 500 GB Flash Storage SSD, macOS 10.14.6
Pro Tools|Ultimate 2020.5, Logic Pro 10.5, Nuendo 10.3, Cubase Pro 10.5, Reason 11.3, Live 10.1, Digital Performer 10.11, Studio One 5, Waveform 11.0.26, Reaper 6.08, WaveLab Pro 10.0.40
Waves Horizon/Diamond 11.0.58, Melodyne 5, iZotope Post Production Suite 4, iZotope Music Production Suite 3, Soundtoys 5.3
Apogee Quartet, Eleven Rack, 003, Command|8, OWC Thunderbolt 2 Dual-Drive Dock, OWC Mercury Electra 480 GB 6G SSD, OWC Mercury Elite Pro 250 GB 7200 RPM HDD
Problems ! - Eleven Rack Editor- Windows Twelve Entertainment Eleven Rack 4 02-20-2016 03:29 PM
Eleven Rack Editor Problems lungerocks Eleven Rack 0 10-07-2015 08:27 PM
Problems with Eleven Rack Editor stephen.calamia.3 Eleven Rack 1 01-12-2015 10:27 PM
problems with midi editor and tempo moosebox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-01-2011 02:13 PM
Zoomer Problems in MIDI Editor ralphie3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-30-2009 02:37 PM
