Tascam 1800, Protools 9, then 10
Protools 9, Toshiba quad laptop, Tascam 1800, Win 7. In my headphones in phone jack or Monitor out jack I get a doubling effect or echo effect. Input/output both on Tascam. When I set the Master and the Track to Bus the echo goes away but not real power to the headphones unless I crank up the channel on the Tascam, than is peaks to the max on the pt channel, no Master turned up. Just seems to come directly from the tascam, not through protools properly.. What is wrong. Give me your setup. I have driver set to high latency, not highest, not yet. Give me your setup. 1 channel w/Master Fader and Aux Channel. I always hear an echo,
Re: Tascam 1800, Protools 9, then 10
in a nutshell, Pro Tools has a internal audio feature that other programs dont have or you can turn off. Its no the tascam its just PT.
please help now i could use tascam us 1800 with protools 10 | rickluque12 | Pro Tools 10 | 9 | 12-03-2013 09:01 PM |
Tascam US-1800 | CocoLopez_1 | macOS | 1 | 07-06-2013 02:17 PM |
Tascam US-1800 | travgei | Windows | 3 | 03-23-2012 08:48 PM |
Is Protools 9 cross grade compatible with Tascam US-1800? | sneakyimp | Windows | 5 | 07-02-2011 12:58 PM |
