Old 03-14-2008, 11:45 AM
broken81 broken81 is offline
Default Help Exporting tempo track from protools to cubase.
Ok i use cubase for drum programing and i normally just play the guitar while i write drums in cubase then export the midi track and throw it into protools to record my guitar and mix. But i already recorded the guitars for this band to a click track in protools and made all my tempo changes and stuff there. I just need to export or get a tempo track so that cubase will have all the tempo changes ready and i can just go about programing my drums there.
Old 03-14-2008, 09:56 PM
spkguitar's Avatar
Default Re: Help Exporting tempo track from protools to cubase.
You should just be able to export a MIDI file from protools and import it in Cubase.
Old 03-15-2008, 07:29 AM
see i did this and all my markers from protools show up but the tempo is still 120 in cubase?
Old 03-15-2008, 08:05 AM
SeedGuy SeedGuy is offline
There are 2 different tempo modes in Cubase, as there are in Pro Tools, One of them will follow the tempo map, the other won't. On the Cubase transport there should be 2 options above the or next to the tempo.
Hope this helps.
Mike
Old 08-07-2017, 03:11 PM
skilletaudio skilletaudio is offline
I know this is an extremely old post but for anyone else that might come across this you have to export a MIDI file in Pro Tools as was stated already. In Cubase it is not as easy as it could be, you have to import the MIDI file into a new session when it asks you to make a new session otherwise the tempo map will not work. Then you have to export a Tempo map from that new session and import the tempo map into the session you already have in Cubase. Setting new bar numbers in Cubase is not as easy as Identify beat in Pro Tools and though tempo marks will be there they won't necessarily be on the same beats that Pro Tools exported them as.
Cubase is in some ways nicer with the auto tempo map but more difficult in not having an identity beat option.
Exporting sections of a tempo map crazy_ow Pro Tools 9 3 12-26-2011 08:48 AM
Exporting from Cubase SX3 Lennie Pro Tools M-Powered (Win) 1 11-03-2005 10:21 AM
Exporting Midi FIles Form Cubase SX into Protools Angelo Miguel Santos Pro Tools TDM Systems (Win) 1 06-09-2005 09:26 AM
Exporting Pro Tools LE files to Cubase SX? GregR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-25-2003 05:12 PM
Need Help Exporting Audio tracks from Cubase SSRJazz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-28-2002 07:11 PM
