Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Dock
Old 05-11-2018, 07:05 AM
spoons's Avatar
spoons spoons is offline
Default Dock Fader - Attention Problem
PT 2018.4 Eucon 18.3
Can somebody tell me if this behaviour is a bug or a function that I’m missing.
I’m using just a Dock on it’s own. Under Assign I have Dock fader to <attentioned/selected track>.
Sometimes - and this may be because it’s intermittent or I’m somehow actioning it - when I attention a VCA I get a flashing green light next to the name in the bottom left corner of the Control screen where the attention faders details are. I then can not attention away from it. When I attention away everything else follows like the EQ and Dyn etc but not the fader. Somehow after a while I get it back and alls good until the next time.
I thought that this may be something to do with Spill but I have that turned off in prefs.
I've had the Dock for almost two years and use it every day but this problem has just started ?
Thoughts ?
Richard Spooner
www.spoonsound.com
Old 05-11-2018, 03:37 PM
Maro Records's Avatar
Maro Records Maro Records is offline
Default Re: Dock Fader - Attention Problem
It's normal behaviour for VCA Spill.
But if you have it turned off ... it's odd.
Well, I've noticed that PT 2018.04 is buggy, or Eucon needs update.
Anyway - I returned for PT 2018.03 which works great with Eucon 18.3...
Maro,
http://www.marorecords.com
Old 05-12-2018, 04:59 PM
spoons's Avatar
So a bug then ?
Richard Spooner
www.spoonsound.com
Old 05-12-2018, 10:44 PM
EddieJones's Avatar
Can you check the VCA spill setting - Single master Mode ? (In EuControl prefs)
Old 05-14-2018, 07:11 AM
spoons's Avatar
Eddie.
It's on "Assign VCA Master to Dock"
Richard Spooner
www.spoonsound.com
Old 05-14-2018, 09:41 AM
BScout BScout is offline
Just to clarify, you have "VCA Spill Overrides Layout" unchecked?
If so, try checking it and then unchecking it (in essence, toggle the setting). It should be unchecked for what you want.
Pro Tools Ult 2018.12, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 05-15-2018, 08:04 AM
spoons's Avatar
I did a mix today and didn't get the problem I had. I did toggle the "VCA Spill Overrides Layout" and this seems to have fixed it.
This problem started with this particular Pre-mix I'm doing where I had been given a template by a facility who have a Dock / S3 set up. I think that's how it got turned on.
Thanks for everybody's help
Spoons
Richard Spooner
www.spoonsound.com
Clear the Attention Fader? hixonjames Pro Tools | S6 1 07-23-2017 10:10 AM
Attention Fader (??) KeyplayerG Artist Series 3 03-26-2017 07:05 PM
Fader off on Dock?? KPereira Pro Tools | Dock 1 02-13-2017 01:22 PM
Suggestion: Users of S3&Dock together: dock fader becomes 5th VCA master fader bassmagnetic Pro Tools | Dock 0 10-01-2016 09:20 AM
Artist Series Attention select fader bug Cryos Artist Series 1 02-17-2015 05:36 PM
