Old 10-14-2012, 04:00 AM
ilulilu888 ilulilu888 is offline
Default Omni Firmware update problem
i was guided to update the firmware of the HD Omni - which is 2.6 while current version is 3.0
i tried to begin the update but i got this message :
PROT 1 PRIMARY DEVICE PROGRAMMING FAILED : DATA VERIFICATION ERROR ON FASH DECTOR 0
WTF????
Pro Tools 12HD
HDX 1
Avid HD 8x8x8
Avid Omni HD
MacPro 2.4 Xeon 8 core 24Giga
UAD-2 And most of the UAD plugins
All AAX DSP and Native Plugins (all most)
Tons of Hardware...:)
Old 10-14-2012, 10:57 AM
Default Re: Omni Firmware update problem
Bump
Pro Tools 12HD
HDX 1
Avid HD 8x8x8
Avid Omni HD
Old 10-14-2012, 04:49 PM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
I found this on the avid support forum for this problem, specifically if you ran digitest before the firmware update:
Restart computer and HD Omni.
Before running the Main Test on Digtest, update the firmware on the HD Omni.
After the hardware has been updated you may run the main Test.
Old 10-15-2012, 08:52 PM
DetroitT's Avatar
DetroitT DetroitT is offline
My version and DigiTest is 2.1 (HD Omni with HDX)
where is 2.6 or 3.0 information?
Old 10-15-2012, 11:02 PM
Hey detroitT
I'll explain : I posted this post before I got the HDX card... I tried upgrading the firmware on the omni with my old accel system ,so the omni was not even recognized by digitest (it was described as a192)....current version is 2.1.... Don't worry... you haven't missed any version.
Pro Tools 12HD
HDX 1
Avid HD 8x8x8
Avid Omni HD
Old 10-16-2012, 04:12 AM
DetroitT's Avatar
Thank you.
(One less thing to-do)
Been trouble shooting and and reinstalling....... for those pesky (On my system) clocking errors.
Old 10-17-2012, 12:15 AM
phatbeatstudio phatbeatstudio is offline
Digitest is what does the firmware update so what would be the problem
After all the firmware updates iv made I really got see the size of that rack. its gotta be a double bay at least
Old 08-06-2013, 05:03 PM
neves20 neves20 is offline
Originally Posted by ilulilu888 View Post
Hey detroitT
I Have the exact same problem with my accel system.., the digitest is not recognizing the Omni? From what I understand 2.6 is the old firmware with the noisey fan problem..2.10 is the newer firmware.. and after reading this post I can conclude that if you own and hd accel core system with the Omni there is no way to update your firmware unless you have the new HDX system??
pls tell me Im wrong
Old 08-06-2013, 10:03 PM
nst7 nst7 is offline
2.10 is the most current version. Not sure about the HD vs. HDX thing.
Old 08-09-2013, 03:17 PM
Ok so I have figured out how to solve this firmware update problem on the accel core system with HD Omni
1. power down everything
2. disconnect the digilink cable from the back of your core card..while leaving the other end still plugged into the omni.
3. now with the cable disconnected from the core card power on ¥our computer
,when you see the home screen, shut down the computer.
4. plug the omni back into the core card...with everything off.. first power on the omni and do a factory reset under the setup options.
5 then trun on the computer.. you may hear a beep or a sound come from your computer on start up.. once everything is running open digitest.. and click the firmware update tab.. it should show the omni as the interface ready to be updated.. run the update... then power down the computer.. then power down the omni.
6. power on omni again then the computer and you should be able to run everything nice and smooth...
7. note: this worked for me with the latest PTHD10.3.6 update
How do I update Omni firmware if Digitest wont open? basicbass Pro Tools HDX & HD Native Systems (Win) 1 04-02-2013 01:28 AM
No ASIO after Omni firmware 2.10 update? Shan Pro Tools HDX & HD Native Systems (Win) 14 03-31-2012 02:49 PM
firmware 1.0.3 update problem Enchilada Jones Eleven Rack 5 03-24-2012 10:59 PM
HD Omni firmware update CDac Pro Tools HDX & HD Native Systems (Mac) 3 08-01-2011 11:27 AM
HD-OMNI´s ADAT I/O dead...Firmware problem? 24BitMusic Pro Tools TDM Systems (Mac) 3 01-03-2011 08:55 AM
