Old 11-07-2011, 09:59 AM
senik343 senik343 is offline
Question How do I monitor "output" audio levels of a track
Hi all,
I'm new to Pro Tools and new to the forum. I've searched for a solution to this online and in the PT9 help, but apologies if it's already been answered a million times. Also I'm sorry in advance if I'm breaking any forum rules.
PROBLEM:
After making edits to the automation of a region, there is a noticable audible change in the output level, relative to the edits I've made. the fader also moves accordingly upon playback.
However the audio meter for the track doesn't show these changes. This is making it difficult to adjust the automation accurately.
QUESTION:
Is there any way to change the audio meters to reflect output audio as opposed to the original levels?
Thanks in advance.
Old 11-08-2011, 04:19 PM
Glitch Magnet Glitch Magnet is offline
Default Re: How do I monitor "output" audio levels of a track
Page 211 of the v9.0.2 Pro Tools Reference Guide. You want to set your track metering to "post-fader".
"Pre- and Post-Fader Metering -- You can globally set audio track level meters to indicate pre- or post-fader levels. When prefader metering is selected, the level meters show levels independent of fader position. With postfader metering, the level meters respond to fader position.
To toggle track level metering between pre-fader and post-fader metering: Select Options > Pre-Fader Metering."
Old 11-09-2011, 07:36 AM
Well said^^^ and I would add; don't mix with your eyes, use your ears
"No output device selected in Studio Monitor Express, using Default Output"?? Focuret Pro Tools 10 4 01-11-2014 02:31 PM
Channel I/O keeps loading old I/O and not "no input"/"no output" Arve Gotfredsen macOS 4 02-12-2013 04:38 AM
Opening freezes at "Reactivating track monitor" vnetstudio Pro Tools TDM Systems (Win) 2 05-04-2012 02:26 AM
If I "Remove Unused Regions" after "Consolidate", track won't play? el biciclista Pro Tools TDM Systems (Mac) 10 04-02-2003 10:17 AM
setting levels "naturally" vs. what "the books" say Felix Tips & Tricks 8 12-19-2001 05:23 PM
