Old 07-13-2019, 08:29 PM
BScout BScout is offline
Default Re: Delay Compensation screws up VI timing
Originally Posted by kirkbross View Post
He also runs 7 HDX cards.
I assume in different systems as a total (otherwise there's some lack of truth going on.)
And HDX cards have no influence on VIs. The last VI I heard that could use ProTools DSP was back on TDM with Virus. Maybe a synth from Plugin Alliance today -- haven't checked. But no samplers, etc.
Old 07-13-2019, 09:34 PM
amagras amagras is offline
Originally Posted by arche3 View Post
https://support.native-instruments.c...-11-or-Higher-
Try this. It works for me. But better to just get vepro
Sent from my SM-G975U using Tapatalk
This article is very well written and clear, it also hints cleverly whose fault it is. Should have solved OP problems
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 07-15-2019, 11:43 PM
Becharax's Avatar
Becharax Becharax is offline
I dream to be able to throw in UAD plugins on Instrument Tracks in Pro Tools without any need to adjust any delay compensation with Audio Tracks in sync #Justsayin
System Details:
iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
Apogee Thunderbridge/Apogee Symphony I/O 2x6
Eleven Rack/Focusrite ISA Two/Onyx 1640i
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Axiom AIR 49/Axiom 49/Yamaha P35
Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e
Genelec 8040b/Yamaha HS80s/M-Audio BX5a
Beats Solo/Shure SRH1840/Slate VMS
https://open.spotify.com/artist/7KfV..._branch=1&nd=1
Old 07-16-2019, 03:07 PM
smokeydan smokeydan is offline
To the O/P
The virtual instrument you're running - is it being played by MIDI on the same instrument track that the VI is inserted on? Or is it somehow being played/sequenced within the plug in itself? Or from a separate MIDI track?
I have found (with a certain percussion NI VI) that when the pattern is being triggered by a sequencer within the plug in itself, it played out of time on an instrument track. I believe this is because delay compensation on Instrument tracks is dealt with in the MIDI domain (ie before the VI), not the audio domain (after the VI). The fix was simply to move the VI to an Aux track, where delay compensation was dealt with in the audio domain/post the plug in. All back in time.
I have also had issues with delay compensation where I had MIDI on a separate MIDI track playing a VI on an Instrument track. playback was again out of time - In that instance I think I solved it by simply copying the MIDI to the instrument track instead.
Mac Pro 5,1, 2 x 3.46Ghz six core Xeon, 64GB RAM, Mojave, PT Ultimate 2022.10, H/D Native PCie, Avid Omni interface.
Mac Pro 6,1 12 core, 64GB RAM, Catalina, PT Ultimate 2022.10, 2xHDX cards & UAD Octo PCIe card in Sonnet TB Chassis, 2 x Lynx Aurora 16 interfaces.
MacBook Pro 32GB RAM Catalina, PT 2022.10, UAD Apollo X4
MIDI timing / recording delays with Delay Compensation DAWgEAR Pro Tools 10 23 03-08-2020 06:12 AM
Control 24 screws up IO settings and Delay Compensation meech Pro Tools 10 0 11-24-2011 12:30 PM
Delay Compensation Timing problems with RTAS plugs Kourquie Pro Tools TDM Systems (Mac) 2 07-22-2007 03:50 AM
Rtas / midi timing compensation bluesna 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-27-2006 07:00 PM
"Compact selected" screws up timing 'til reopen? strider07 Pro Tools TDM Systems (Mac) 2 12-30-2004 03:03 PM
