Old 09-29-2016, 06:10 AM
pyrmont25 pyrmont25 is offline
Default 12.6 layered editing not what it should be
Just got 12.6. Layered editing turned on. Placed a small clip over a larger clip, removed small clip and larger clip still intact as expected. HOWEVER place a large clip over a small clip and small clip disappears! I thought the whole point was to retain the clip underneath? I hate when you accidentally place a clip over another(shorter) it disappears. I expected this new layered editing to have sorted this!
Old 09-29-2016, 06:25 AM
Pete Gates Pete Gates is offline
Default Re: 12.6 layered editing not what it should be
It's a preference you can set - whether it moves it to a new playlist or not.
Pete
Old 09-29-2016, 06:31 AM
Ah ok thanks. What preference?
Old 09-29-2016, 06:32 AM
cut cut is offline
From the video that I watched - it is supposed to create a new playlist underneath, if you enable that in pref's. Check your playlists for the smaller clip.
Old 09-29-2016, 06:33 AM
Setup / Preferences / Editing / Send Fully Overlapped Clips to Available Playlist While Editing
Old 09-29-2016, 06:36 AM
Found it. Don't understand why this should be any different!
Old 09-29-2016, 06:53 AM
Drew Mazurek's Avatar
Avid engineering is handling this slowly, as it should IMO. Hence prefs like Pete mentioned etc.
Changes this fundamental to the workings of PT should be eased into.
Expect Layered Editing to continue to be enhanced as time goes by.
www.drewmazurek.com
Old 09-29-2016, 08:39 AM
cut cut is offline
To be honest it is a new feature - so it really can't be any different because there is no departure point from which to judge a difference.
Old 09-29-2016, 03:02 PM
jamesregan jamesregan is offline
Track Compositing Shortcuts....
I can't speak for the PC versions of these but looks like the mac versions are not as described in the pdf doc.
(Move the selection to the main playlist Option+Control+M) is actually OPTION SHIFT M?
(Copy the selection to a new playlist Control+Shift+Left Arrow) is OPTION SHIFT DOWN ARROW?
(Move the selection to a new playlist Control+Shift+N) OPTION SHIFT N?
Why Pan Layered Sounds In XPAND2 If.. MIKEIKE Pro Tools | Intro Discussion 0 10-06-2015 12:43 PM
Midi to audio layered tracks bobbyrichards Pro Tools 10 0 03-27-2013 01:28 PM
how to swap layered, looped takes in pt8? c-post Pro Tools TDM Systems (Mac) 4 03-11-2013 04:32 AM
Creating a Layered Instrument...Using Xpand! Avid Virtual Instruments 0 02-15-2006 07:40 PM
Burning CD's, bits of music layered where they don't belong michaelwalker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-16-2002 08:33 PM
