Old 06-17-2017, 05:35 PM
29CountsNY's Avatar
29CountsNY 29CountsNY is offline
Default Matching 2 mono hardware EQ in DAW on master bus
I know this probably a dumb question but I'll ask anyways.
I want to use my Harrison 32eq's on the master bus as hardware inserts. Since these are mono units, what's the best way to make sure that I am applying the same EQ to the left and right signals?
Any suggestions or tips would be appreciated!
www.montabonsound.com
www.29counts.com
Pro Tools HD 2019.12 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection
Old 06-18-2017, 02:52 PM
albee1952 albee1952 is online now
Default Re: Matching 2 mono hardware EQ in DAW on master bus
This might be a great case for waves Q-Clone. You set 1 and then clone it with the plugin to both sides. Beyond that, you could set one, then feed it with pink noise and then set the other to match it(yes, this would be somewhat of a pain). Or monitor one side only and insert both EQ's in line, bypassing one at a time and tweak until you hear no change. Then repatch
Having said all this, is there not a plugin version that would save all the hassle?
Old 06-18-2017, 03:51 PM
amagras amagras is offline
You have nothing to lose trying by ear, monitor with an LR balance monitor to make sure the bass stays in the center.
Other idea could be splitting your mix in 2 mono tracks and use the same eq with the same settings on one side at the time.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 06-19-2017, 02:41 AM
joachim's Avatar
joachim joachim is offline
Convert L-R to M/S, process and back ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 06-19-2017, 04:45 AM
Yep - UAD has one and op already has a UAD device. http://www.uaudio.com/uad-plugins/eq...rison-32c.html
Jack
QAPLA!
Old 06-19-2017, 09:48 AM
29CountsNY's Avatar
Thanks for all the responses.
The reason I was looking at using the hardware 32eq's was because I am using my Dangerous Music 2BUS to do 16 channel analog summing so I was thinking about strapping the 32eq's in the chain on the way back into Pro Tools.
I am going to give it a go with trying by ear and then see if I can use a Freq Analyst app like Blue Cats to see if I can get it close.
Truthfully it will be easier to setup an Aux track on the 2 tracks coming back in and just setup plugins on that track and route it to an Audio track to record so I can get the effect of the plugins in the box. And recall will be SO much easier.
I was just hoping for a plugin or app that would allow me to see the result of the 32eq on the way back in and then try and adjust to get them close.
Might be on to a new idea for a product though....
www.29counts.com
Issues with Hardware Insert I/O's matching Patchpoints on 3 192's NYUTECH Pro Tools 10 2 03-13-2013 01:03 AM
mono master keenast Tips & Tricks 2 04-13-2011 11:54 PM
Mono Master I/O setup Dean Smith 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-22-2009 06:58 PM
Anyway to get 2 mono effects to sync on master? joey1243 Digidesign Hardware & Software 2 11-10-2000 02:10 PM
Anyway to get 2 mono effects to synch on master? joey1243 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-10-2000 01:34 PM
