can\'t play XP system sounds or iTunes thru Mbox
1) I cannot play WinXP system sounds thru my Mbox. They continue to go thru my sound card. I have run the Digi MME Helper to assign programs to the WaveDriver. But I don't know which app/dll controls my system sounds, so I don't know what to add.
2) Also, when I play music, it gets successfully routed to iTunes and the Mbox, but the resultant audio is distorted. It sounds like it's behind a fan (i.e. choppy). I have the Mbox set as my default sound hardware in Control Panel->Sounds & Audio Device->Audio tab. Software: PT LE ver. 6.1.1 iTunes ver 6.0.1.3 |
Re: can\'t play XP system sounds or iTunes thru Mbox
Have to change to MBox to be your audio interface in Quicktime, reboot and your done. A quick search on this topic would have answered that for you. Question already asked.
** Cant listen to itunes and have Protools open at the same time and vise versa** Good luck! |
I don't know if this is will do it for non HD system but here is the procedure I got from DigiCS.
John 3:16 |
Safe Mode wwas the key. It works on LE systems also.
Thank you! |
I don't think so. A quick read of my post would have revealed the Mbox as my default playback hardware. Keep your editorials to yourself.
Anyone figure out how to play system sounds through HD Omni? | agershon | Pro Tools HDX & HD Native Systems (Mac) | 46 | 05-09-2018 11:24 PM |
Play computer sounds (iTunes, Winamp, etc.) through Digi 002r | kierkegaard | Windows | 8 | 05-05-2013 07:05 PM |
System sounds don't play thru Mbox2 Pro in W7 Pro w/ PT 8.0.5 le | scott_nikki1216 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-28-2011 02:11 PM |
Pro TOols playback is OK, system sounds and other sounds won't play | bimple | Windows | 1 | 08-24-2011 05:14 PM |
How do i get sounds (itunes, internet, real player etc...) to play out of Digi 001? | Holmes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-28-2003 05:06 PM |
