Old 08-19-2017, 06:33 PM
groovebrother groovebrother is offline
Default cannot access pro tools 5.3.1 cs 7 update
hi
i need to get back to mac os 9.2.2 in order to use rebirth wich wasn't updated for osx.
My G4 MDD is still in good shape, i could launch pro tools 5.3.1 but i get the following message : your clock is set to a date that is inconsistent with the release date of digitranslator
i checked the clock nothing's wrong with it
AND as said in the subject i cannot access to the cs update
any clues ?
best regards
Old 08-25-2017, 06:55 PM
panamajack's Avatar
panamajack panamajack is offline
Default Re: cannot access pro tools 5.3.1 cs 7 update
Have you tried setting the computer's clock to some day in 2001 or 2002? ...back when 5.3.1 was current?
PT10.3.10HD(Tyan s2932 [8core Shanghai 2.7GHZ] 32GB,Win7 SP1); PT10HD(Tyan s2892 w/10GB, Win7 SP1);PT8HD(Dell 690 quad Xeon 3.0, 8GB, Win7,192 I/O, 96 I/O);MacBook Pro: 11R, Apogee Element 46, Focusrite 8PreX PT HD 11.3.2; Mac Pro 3.47 Hex 32GB, OSX 10.12.6/L10.3.3;L9.1.8, 2.64TB; G5 D2.3 4GB, 10.4.11/L8; 12c MP 2.66/32GB PT12.4; Structure, GigaGS3, Kontakt 5, Garratin, Sibelius 8.5+, Finale25,EMU,Vegas Pro 14-10/; RME HDSP9652,MOTU 2408 MKIII/1224/308, FX,Kurz,L5s,Strat,ASAT,JB,Zon
Old 08-26-2017, 04:27 AM
thx Panama
problem solved : clean install without digitranlator
got in touch with the ACS but he send me cs6 update instead after sending me LE update
so still waiting
but i have new issues : i get error messages saying the ribbon is not set properly but, i have tried all cards positions, all possible tdm ribbon connections and still same message.
I am using core + 2 accels cards + 2x 192i/o
i even tried to reset pram+mother board
I of course tried other tdm ribbons BUT the originals ones are fonctionning perfectly with 10.5 and PTHD 8
so what's wrong with pro tools 5.3.1 ? i don't get it
Old 08-26-2017, 10:13 AM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Iirc 5.3.1 was the only OSX release for HD cards, and Accel cards didn't exist when it was made. If the CS updates don't specify Accel compatibility, I'm guessing you need to switch your accels to the older HD process cards to eliminate the error message. Your core card is essentially identical DSP to an Hd process card, so you could also run just an HD1 if that's enough to do what you need to do with rebirth. Even if there was a CS update for accel compatiiblity, it probably didn't see extensive testing since digi was much more focused on the transition to OSX at the time.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 08-26-2017, 10:29 AM
ah yes thx for the clue about accel cards - i forgot this point.
okay i'll try with process cards then
makes me also realize that rebirth might not work into pro tools trough rewire and that i will probably need to record what comes from rebirth into another pro tools wich will do the trick anyway
thank you
Old 08-26-2017, 02:36 PM
s.d. finley s.d. finley is offline
rebirth doesn't support rewire. However, you could use the IAC bus to sync PT and Rebirth together. Use the macs built in outputs, or another sound card, and input these back into PT.
sdf
sugarhillstudios.com
Old 08-26-2017, 02:39 PM
Thx for the reply but i'll be using the other pro tools to record what comes from the digidesign audio engine with rebirth
The mac outputs have always been kinda noisy to me
Old 08-27-2017, 07:56 AM
Mdd g4's were one of the earliest macs with optical digital out. You'd need an 1/8" optical to toslink cable(easily found on ebay for a few bucks) but that is another way of doing it without going through DA-AD.
- John
Old 08-27-2017, 08:13 AM
yep thanks
but i guees i'll stick with analog recording trought valve preamps to warm it up a bit and add a little coulour
besides no digital out on my G4 MDD wich is a 2x 1ghz - i thought this had come with G5
Old 08-27-2017, 08:54 AM
digital out started with the latest version of dark gray g4's. AFAIK all quicksilver and MDD g4's have it, but I have never tried to use it with OS9, so might need OSX for the drivers.
- John
Pro Tools 10 Access Violation after installing Pro Tools 12 dalves Pro Tools 12 3 05-23-2017 01:50 PM
No access to registered email, & wanna upgrade PT. DO have access to associated iLok SATP Pro Tools 9 1 06-06-2011 07:21 PM
Please update any firewall rules permitting access to the DD central site cmarkle_aspera Aspera DigiDelivery 2 02-04-2009 06:32 AM
Can't access Firewire 1814 mixer page after OSX update bradwarren Pro Tools M-Powered (Mac) 1 11-27-2007 08:44 AM
Help: No Access to ProTools LE after Macbook Pro Update protoolsjimmy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-30-2007 07:44 AM
