Avid @ NAMM 2018
Old 08-04-2017, 08:08 AM
mbmusic mbmusic is offline
Default no input signal in pro tools 10 HD
Hi, a friend of mine has a problem with his Digi 192 and I try to help him. I am not an expert in HD Systems so I would be happy for a useful hint.
From one to the other day there are no input signals in pro tools (I don't know if he changed something). On the Hardware IO is an input signal - So it looks more like a software issue.
- I already checked the I/O configurations in Pro Tools (everything is set -
- correctly). When I open the core manager it says: not connected (hw in
use)
- and when I press the connect button nothing happens.
- PT does not show any Preamps in the mixer/Edit window either
Grateful for every tip!
PT 10.3.1 is running on OSX 10.7.5 with a C24
Old 08-08-2017, 01:22 AM
rosietesmen's Avatar
rosietesmen rosietesmen is offline
Default Re: no input signal in pro tools 10 HD
you just have to reset your I/O setup configuration to reflect the currently connected device :) Then try again, hope will help :)
Old 08-08-2017, 03:39 AM
Hey, thank you very much for your reply. I made the reset of the IOs (you mean the ones in pro tools?)on the pre is a signal but the 192 is still not connected. the problem is: when I use an other output/input in the audio midi setup of osx the 192 connects in the core manager, but then no output or input works (sounds come from the build in speakers of the mac pro). I don't know if there is a known standard configuration?
Old 08-08-2017, 02:24 PM
Barry Johns Barry Johns is offline
Wait, what?
You cannot use your 192 to playback your computer audio. As far as Protools, you don't need to use OSX's audio for anything related to Protools.
In Protools I/O settings is where you tell Protools how to route your I/O of your 192. I suggest you google how to setup Protools I/O and watch some videos.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 08-08-2017, 06:29 PM
Hi Barry, I already did anything possible in pro tools...no luck I know osx audio is seperate and the 192 can't play computer audio. That's why I am so confused . ... The system worked perfectly until someone changed something in the audio midi setup in osx. Depending what in or output in osx is marked the interface connects or not in my case (after reboting). But I will reset the PT ios tomorrow again. Thanks!
Old 08-09-2017, 11:14 AM
s.d. finley s.d. finley is offline
sounds like PT is using the built in mac i/o for sound. Change it to the HD engine in the OS X audio midi setup
Old 08-09-2017, 04:33 PM
It works! the Audio preferences in OSX had to be deleted and the Pre used digital audio I in the PT IOs instead of analog. Thank you guys for your hints!
No input signal in Pro Tools from Eleven Rack AxeVictim Eleven Rack 6 06-13-2017 10:59 PM
No input signal in Pro Tools Universus Pro Tools Software (Mac) 20 02-26-2017 12:58 PM
No signal in Pro Tools using UAD Hi-Z input [solved] darknesscrown Pro Tools 12 7 11-28-2016 07:20 PM
Pro Tools LE8 No Input Signal? RyanChappell1987 Pro Tools Software (Mac) 14 01-18-2014 08:33 AM
No Input Signal - Mbox 2 - Pro Tools 8.0.5 davemeasom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 04-27-2012 04:42 PM
